I am seeing wear at the Barrel/Valve Plate interface of the axial piston pump I am designing. We were using nitrided 15-5 on nitrided 15-5 but we are now looking at a bronze barrel with "Kingsbury Pads" on it running against a thru-hardened valve plate. The pump must see a range of pressure between 0 and 3000 psi and speeds between 0 and 10,000 RPM for an aerospace app.
Any recommendation on Kingsbury pad design or what barrel bronze materials to use? Galling studies?
I don't think dirty fluid is the problem because I attached a Vicker bent-axis pump to to the system and that unit shows no signs of wear.
Also, how does one achieve the amazing flatness and surface finish of a Vickers, or similar, valve plate and barrel?
