The weld procedure says "Base metal thickness range " 5/8" to 1.5" ". Using this procedure can I weld the 18" std flange on to the 18" pipe as per attached sketch?
The flange thickness is 56mm. I know that this is more than the base metal thickness mentioned on the WPS but it somehow comes to my mind that base metal thickness is of importance only on full pen groove welds. I may be wrong. Please help.
