Base shear from ETABS 2
Vonx
5
Hi all, I've got a question about the base shear. After you do the response spectrum analysis in Etabs, how do you find the total base shear of the structure(multi-storey building to be more specific)? This is to work out the scaling factor. I was told that you can look at the "Story force" section of the 1st storey of the structure in the output report. Is that correct?
No, that's not correct. Under Display menu>show tables, checkbox reactions/support reaction. There is a "summation" base shear reported along with individual restraint reactions. You can control which cases are to be reported using the options on the right side of the show tables.
You can get Story shears:
1) Display/ Show Story Response Plots.../ Story Shears
2) Display/ Show Tables.../ Building Output/ Story Shears
Drile007
Thanks guys, that helped.
Hi stressed:
I was able to do the show table thing, thanks for that. However, I could not find the "summation" function mentioned in your last post. I had to manually add all the reaction forces together under same direction to find out the base shear. Would you please give some instructions on this one?
Vonx, apologies, I was mistaken in my earlier reply regarding what the "summation" option offers you. I have been working more with SAP lately and I gave you some misleading advice. Here is what you need to do to obtain the summed base shear that you want - First, select all joint restraints at the base of your model, as well as the first floor columns and walls which are connected to those restraints, and assign them all to a group. Next, use Define menu>Section cuts and define a section cut based on the group you just created. After you've run your analysis, using Display menu>Show tables>Section cut forces, you should have the summed base shears. Let me know if that technique doesn't do what you're looking for.
Hi to stressed/drile007:
Thanks for the replies. I have done a comparison using both the story shear method and the section cut forces summation method to calculate the base shear. In my case, the values are very close:
Vx (story force) : Vx (section cut) = 1 : 1.03
Vy (story force): Vy (section cut) = 1: 0.98
As you can see, the differences are within 5%. I tend to believe both methods are valid in terms of calculating the base shear using Etabs. Please give your comments.
Vonx
You should have a look at Display -> Show Tables -> Modal Information -> Table: Response Spectrum Base Reactions. They have had to introduce a special routine to determine base reactions since all results from Response Analysis are positive. Summing base reactions or column shears would be wrong.
GarthW
