Hey Everyone,
I have a ground supported steel tank that I am designing foundations for. The tank will be welded down to embed plates (of my design) placed into a large mat slab. For anchorage I planned on designing the embed for any uplift resulting from overturning from seismic or wind. For shear my plan was to count on the friction between the embed and the concrete. I've seen discussion on on this topic as it relates to columns baseplates and it seems there were a fair amount of opinion to NOT use friction for shear resistance.
Considering all load combinations and including the vertical shear force (reducing the gravity load) it seems reasonable to assume the down loads on my embeds could be counted for friction. When all is said and done I get a unity check of around U=0.4 for base shear/friction resistance.
Given the case would you have any issues counting on friction for shear resistance?
Thanks in advance!
Thanks in advance!
