HZStruct
- Feb 16, 2021
- 10
I am checking the overturning stability of a slab-on-grade supporting a pipe support. I am checking the overturning about the bottom edge of the slab, which is 14" below finished grade. My resisting force is the sum of the vertical load (weight of pipe and concrete slab). My question is related to the overturning force. Do you consider the overturning moment of the slab in addition to the overturning moment from the weight above the slab? Is it too conservative to include the overturning affects from the slab?
Thank you for the help in advance!
