I have a pinnion of 10 teeth, 48 dia. pitch, 14.5 degree pressure angle, brass material which is driving a brass hear sector of 100 teeth. 48 DP, 14.5 pressure angle as well.
Out of the calculation I got the center between axis of 1.1458 inch. In real I measured a bigger distance: 1.1542 This kind of gearing is used in an actuator and we need to reach a particular number of cycles (over 100,000). The thing is I got failures around 25,000 cycles, the pinnion has teeth chewed-up. That happend using brass material for the pinnion. I switched to bronze material for the pinion and I got over 150,000 cycles. No damaged pinion at all. Still the same distance between axis (1.1542)
My questions are:
1. How much are you allowed to vary the distance between axis and how is this going to affect the meshing if is bigger than the calculated distance.
2. Why a diffrent material acts better (bronze in this case) than the brass knowing that is the same tooth profile for the pinnion. I would like to go with brass material because is cheaper.
3. Could you explain what coefficient of profile means and how you calculate this?
thanks,
ediushu
My questions are:
thanks,
ediushu
