Basic Strength of Materials Calculation ???? 2
dtwo
Automotive
Oct 17, 2002
137
I am working on a shaft failure and I came across something that puzzles me.
If I look at Mechanical Engineers handbook it lists a formula for maximum stress in center of a beam where the load is applied in the center with supports on the two ends being: WL / 4Z
W: weight
L: over all length
Z: section modulus
However from strength of materials class many moons ago I remember using Mc / I for stress due to bending. What is the difference?
Well the units work out, do you know if you get the same answer?
Tobalcane
"If you avoid failure, you also avoid success."
WL/4Z is derived from Mc/I...
The section modulus is defined as Z = I/c
Also, (for a beam of length L, simply supported on each end with a load, W, applied at the center) the maximum moment is
M = WL/4 (at dist = L/2)
If we insert these into your standard Mc/I equation, this leads to the equation,
WL/4Z
The difference is that this equation is specific for this loading configuration and Mc/I still holds for *any* bending loading configuration.
I would suggest getting a copy of Roark's Formulas for Stress & Strain.
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 3.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"First they ignore you, then they ridicule you, then they fight you, then you win." - Mahatma Gandhi
Probably read timoshenkos basic books, as they would also give a good refresher to the grey matter.
