Batch export DXF/DWG from folder to folder
juki-hao
7
Hi everyone,
I am trying to combine the VB code from these two Journals:
My purpose is to batch export from prt to dxf/dwg files, from folder to folder.
This is what it looks like:
Code:
'NXJournaling.com
'December 1, 2014
'export pdf's of all parts in the given folder.
'August 5, 2015
'update: fix for the "part scan error: file already exists" error
'  Previous version was not closing assembly components correctly,
'  this left the component file in NX memory. When the journal later
'  attempted to open the part file to process its drawing sheets,
'  the "file already exists" error would be thrown.
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module all_parts_in_folder
    Dim theSession As Session = Session.GetSession
    Dim workPart As Part = theSession.Parts.Work
    Dim displayPart As Part = theSession.Parts.Display
    Dim initialPart As Part = theSession.Parts.Display
    Dim myPdfExporter As New NXJ_PdfExporter()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        lw.Open()
        Dim folderToProcess As String = PickFolder("folder of parts to process")
        If IsNothing(folderToProcess) Then
            'user pressed cancel
            lw.WriteLine("pdf export canceled")
            Return
        End If
        lw.WriteLine("Export PDF files")
        lw.WriteLine("Start Time: " & CType(TimeOfDay(), String))
        lw.WriteLine("")
        lw.WriteLine("folder to process: " & folderToProcess)
        lw.WriteLine("")
        'pick export folder
        myPdfExporter.PickExportFolder()
        If IsNothing(myPdfExporter.OutputFolder) Then
            Return
        End If
        lw.WriteLine("Export folder: " & myPdfExporter.OutputFolder)
        lw.WriteLine("")
        processParts(folderToProcess, False)
        lw.WriteLine("")
        lw.WriteLine("Stop Time: " & CType(TimeOfDay(), String))
    End Sub
    Function PickFolder(ByVal prompt As String) As String
        Dim strPickedFolder As String
        lw.Open()
        Try
            Dim FolderBrowserDialog1 As New FolderBrowserDialog
            ' Change the .SelectedPath property to the default location
            With FolderBrowserDialog1
                ' Desktop is the root folder in the dialog.
                .RootFolder = Environment.SpecialFolder.Desktop
                ' Change the following line to default to a given path
                .SelectedPath = "C:\"
                ' Prompt the user with a custom message.
                .Description = prompt
                If .ShowDialog = DialogResult.OK Then
                    ' Display the selected folder if the user clicked on the OK button.
                    'msgbox(.SelectedPath)
                    strPickedFolder = .SelectedPath
                    Return strPickedFolder
                Else
                    'user pressed "cancel", exit the journal
                    Return Nothing
                End If
            End With
        Catch ex As NXException
            lw.WriteLine("Pick folder error: " & ex.Message)
            Return Nothing
        End Try
    End Function
    Sub processParts(ByVal directoryPath As String, ByVal includeSubDirs As Boolean)
        'Try
        Dim nPartFiles As Integer = 0
        Dim part1 As Part
        Dim files() As String
        If includeSubDirs Then
            files = Directory.GetFiles(directoryPath, "*.prt", SearchOption.AllDirectories)
        Else
            files = Directory.GetFiles(directoryPath, "*.prt", SearchOption.TopDirectoryOnly)
        End If
        For Each fileName As String In files
            nPartFiles += 1
            lw.WriteLine("   " & nPartFiles & " " & Path.GetFileName(fileName))
            If (IsNothing(initialPart)) OrElse (initialPart.FullPath <> fileName) Then
                Try
                    part1 = theSession.Parts.OpenDisplay(fileName, Nothing)
                    lw.WriteLine("open error: " & ex.Message)
                Catch ex2 As Exception
                    lw.WriteLine("exception: " & ex2.Message)
                End Try
            Else
                'LW.WriteLine("initial part equals display part: " & initialPart.Equals(displayPart).ToString)
                part1 = displayPart
            End If
            displayPart = theSession.Parts.Display
            workPart = theSession.Parts.Display
            'do something
            'write your own subroutines and/or functions to process the part and call them from here
            ExportPdfs()
            'close file unless this file was initially open
                'part1.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.True)
                part1.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.UseResponses, Nothing)
                part1 = Nothing
                workPart = Nothing
                displayPart = Nothing
            End If
            If Not IsNothing(initialPart) Then
                Dim partLoadStatus1 As PartLoadStatus
                Dim status1 As PartCollection.SdpsStatus
                status1 = theSession.Parts.SetDisplay(initialPart, False, False, partLoadStatus1)
                partLoadStatus1.Dispose()
                theSession.Parts.SetWork(displayPart)
                workPart = theSession.Parts.Work
            End If
        Next fileName
    End Sub
    Sub ExportPdfs()
        lw.WriteLine(displayPart.FullPath)
        myPdfExporter.Part = displayPart
        '$ show confirmation dialog box on completion
        myPdfExporter.ShowConfirmationDialog = False
        Try
            myPdfExporter.Commit()
        Catch ex As Exception
            'MessageBox.Show("Error:" & ControlChars.CrLf & ex.GetType.ToString & " : " & ex.Message, "PDF export error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            lw.WriteLine("Error: " & ex.Message)
        Finally
            lw.WriteLine("")
        End Try
    End Sub
    Function PartIsOpen(ByVal filename As String) As Boolean
        Dim openParts As New List(Of String)
        For Each temp As Part In theSession.Parts
            openParts.Add(temp.FullPath)
        Next
        If openParts.Contains(filename) Then
            Return True
        Else
            Return False
        End If
    End Function
End Module
#Region "imports"
'** uncomment the imports statments if using this as a standalone class file
'Imports System
'Imports System.IO
'Imports System.Collections
'Imports System.Windows.Forms
'Imports System.Windows.Forms.MessageBox
'Imports NXOpen
'Imports NXOpen.UF
#End Region
'Information for adding this code to your project:
'   if you are going to compile your code:
'       add this class file to your project, create and use an instance of this class in your code
'   If you intend to use this in a journal (no compilation required),
'       make sure all of the imports statements above are present at the top of your journal file.
'       Copy and paste all of the code below here to your journal file (paste it after your "End Module" statement).
'       Create and use an instance of this class in your module.
'       One of the limitations of a journal is that all the code must be in a single file.
Class NXJ_PdfExporter
#Region "information"
    'NXJournaling.com
    'Jeff Gesiakowski
    'December 9, 2013
    'NX 8.5
    'class to export drawing sheets to pdf file
    'Please send any bug reports and/or feature requests to: info@nxjournaling.com
    'version 0.4 {beta}, initial public release
    '  special thanks to Mike H. and Ryan G.
    'November 3, 2014
    'update to version 0.6
    '  added a public Sort(yourSortFunction) method to sort the drawing sheet collection according to a custom supplied function.
    'November 7, 2014
    'Added public property: ExportSheetsIndividually and related code changes default value: False
    'Changing this property to True will cause each sheet to be exported to an individual pdf file in the specified export folder.
    'Added new public method: New(byval thePart as Part)
    '  allows you to specify the part to use at the time of the NXJ_PdfExporter object creation
    'December 1, 2014
    'update to version 1.0
    'Added public property: SkipBlankSheets [Boolean] {read/write} default value: True
    '   If the drawing sheet contains no visible objects, it is not output to the pdf file.
    '   Checking the sheet for visible objects requires the sheet to be opened;
    '   display updating is suppressed while the check takes place.
    'Bugfix:
    '   If the PickExportFolder method was used and the user pressed cancel, a later call to Commit would still execute and send the output to a temp folder.
    '   Now, if cancel is pressed on the folder browser dialog a boolean flag is set (_cancelOutput), which the other methods will check before executing.
    'December 4, 2014
    'update to version 1.0.1
    'Made changes to .OutputPdfFileName property Set method: you can pass in the full path to the file (e.g. C:\temp\pdf-output\12345.dxf);
    'or you can simply pass in the base file name for the pdf file (e.g. 12345 or 12345.dxf). The full path will be built based on the
    '.OutputFolder property (default value - same folder as the part file, if an invalid folder path is specified it will default to the user's
    '"Documents" folder).
    'Public Properties:
    '  ExportSheetsIndividually [Boolean] {read/write} - flag indicating that the drawing sheets should be output to individual pdf files.
    '           cannot be used if ExportToTc = True
    '           default value: False
    '  ExportToTc [Boolean] {read/write} - flag indicating that the pdf should be output to the TC dataset, False value = output to filesystem
    '  IsTcRunning [Boolean] {read only} - True if NX is running under TC, false if native NX
    '  OpenPdf [Boolean] {read/write} - flag to indicate whether the journal should attempt to open the pdf after creation
    '  OutputFolder [String] {read/write} - path to the output folder
    '           default value (native): folder of current part
    '           default value (TC): user's Documents folder
    '  OutputPdfFileName [String] {read/write} - full file name of outut pdf file (if exporting to filesystem)
    '           default value (native): <folder of current part>\<part name>_<part revision>{_preliminary}.dxf
    '           default value (TC): <current user's Documents folder>\<DB_PART_NO>_<DB_PART_REV>{_preliminary}.dxf
    '  OverwritePdf [Boolean] {read/write} - flag indicating that the pdf file should be overwritten if it already exists
    '                                           currently only applies when exporting to the filesystem
    '           default value: True
    '  Part [NXOpen.Part] {read/write} - part that contains the drawing sheets of interest
    '           default value: none, must be set by user
    '  PartFilePath [String] {read only} - for native NX part files, the path to the part file
    '  PartNumber [String] {read only} - for native NX part files: part file name
    '                                    for TC files: value of DB_PART_NO attribute
    '  PartRevision [String] {read only} - for native NX part files: value of part "Revision" attribute, if present
    '                                      for TC files: value of DB_PART_REV
    '  PreliminaryPrint [Boolean] {read/write} - flag indicating that the pdf should be marked as an "preliminary"
    '                                       when set to True, the output file will be named <filename>_preliminary.dxf
    '  SheetCount [Integer] {read only} - integer indicating the total number of drawing sheets found in the file
    '  ShowConfirmationDialog [Boolean] {read/write} - flag indicating whether to show the user a confirmation dialog after pdf is created
    '                                                   if set to True and ExportToTc = False, user will be asked if they want to open the pdf file
    '                                                   if user chooses "Yes", the code will attempt to open the pdf with the default viewer
    '  SkipBlankSheets [Boolean] {read/write} - flag indicating if the user wants to skip drawing sheets with no visible objects.
    '  SortSheetsByName [Boolean] {read/write} - flag indicating that the sheets should be sorted by name before output to pdf
    '  TextAsPolylines [Boolean] {read/write} - flag indicating that text objects should be output as polylines instead of text objects
    '           default value: False        set this to True if you are using an NX font and the output changes the 'look' of the text
    '  UseWatermark [Boolean] {read/write} - flag indicating that watermark text should be applied to the face of the drawing
    '  WatermarkAddDatestamp [Boolean] {read/write} - flag indicating that today's date should be added to the end of the
    '                                                   watermark text
    '  WatermarkText [String] {read/write} - watermark text to use
    '           default value: "PRELIMINARY PRINT NOT TO BE USED FOR PRODUCTION"
    'Public Methods:
    '  New() - initializes a new instance of the class
    '  New(byval thePart as Part) - initializes a new instance of the class and specifies the NXOpen.Part to use
    '  PickExportFolder() - displays a FolderPicker dialog box, the user's choice will be set as the output folder
    '  PromptPreliminaryPrint() - displays a yes/no dialog box asking the user if the print should be marked as preliminary
    '                               if user chooses "Yes", PreliminaryPrint and UseWatermark are set to True
    '  PromptWatermarkText() - displays an input box prompting the user to enter text to use for the watermark
    '                           if cancel is pressed, the default value is used
    '                           if Me.UseWatermark = True, an input box will appear prompting the user for the desired watermark text. Initial text = Me.WatermarkText
    '                           if Me.UseWatermark = False, calling this method will have no effect
    '  Commit() - using the specified options, export the given part's sheets to pdf
    '  SortDrawingSheets() - sorts the drawing sheets in alphabetic order
    '  SortDrawingSheets(ByVal customSortFunction As System.Comparison(Of NXOpen.Drawings.DrawingSheet)) - sorts the drawing sheets by the custom supplied function
    '    signature of the sort function must be: {function name}(byval x as Drawings.Drawingsheet, byval y as Drawings.DrawingSheet) as Integer
    '    a return value < 0 means x comes before y
    '    a return value > 0 means x comes after y
    '    a return value = 0 means they are equal (it doesn't matter which is first in the resulting list)
    '    after writing your custom sort function in the module, pass it in like this: myPdfExporter.Sort(AddressOf {function name})
#End Region
#Region "properties and private variables"
    Private Const Version As String = "1.0.1"
    Private _theSession As Session = Session.GetSession
    Private _theUfSession As UFSession = UFSession.GetUFSession
    Private lg As LogFile = _theSession.LogFile
    Private _cancelOutput As Boolean = False
    Private _drawingSheets As New List(Of Drawings.DrawingSheet)
    Private _exportFile As String = ""
    Private _partUnits As Integer
    Private _watermarkTextFinal As String = ""
    Private _outputPdfFiles As New List(Of String)
    Private _exportSheetsIndividually As Boolean = False
    Public Property ExportSheetsIndividually() As Boolean
        Get
            Return _exportSheetsIndividually
        End Get
        Set(ByVal value As Boolean)
            lg.WriteLine("Set Property ExportSheetsIndividually")
            _exportSheetsIndividually = value
            lg.WriteLine("  ExportSheetsIndividually: " & value.ToString)
            lg.WriteLine("exiting Set Property ExportSheetsIndividually")
            lg.WriteLine("")
        End Set
    End Property
    Private _exportToTC As Boolean = False
    Public Property ExportToTc() As Boolean
        Get
            Return _exportToTC
        End Get
            lg.WriteLine("Set Property ExportToTc")
            _exportToTC = value
            lg.WriteLine("  exportToTc: " & _exportToTC.ToString)
            Me.GetOutputName()
            lg.WriteLine("exiting Set Property ExportToTc")
            lg.WriteLine("")
        End Set
    End Property
    Private _isTCRunning As Boolean
    Public ReadOnly Property IsTCRunning() As Boolean
        Get
            Return _isTCRunning
        End Get
    End Property
    Private _openPdf As Boolean = False
    Public Property OpenPdf() As Boolean
        Get
            Return _openPdf
        End Get
            lg.WriteLine("Set Property OpenPdf")
            _openPdf = value
            lg.WriteLine("  openPdf: " & _openPdf.ToString)
            lg.WriteLine("exiting Set Property OpenPdf")
            lg.WriteLine("")
        End Set
    End Property
    Private _outputFolder As String = ""
    Public Property OutputFolder() As String
        Get
            Return _outputFolder
        End Get
        Set(ByVal value As String)
            lg.WriteLine("Set Property OutputFolder")
            If _cancelOutput Then
                lg.WriteLine("  export pdf canceled")
                Exit Property
            End If
            If Not Directory.Exists(value) Then
                Try
                    lg.WriteLine("  specified directory does not exist, trying to create it...")
                    Directory.CreateDirectory(value)
                    lg.WriteLine("  directory created: " & value)
                    lg.WriteLine("  ** error while creating directory: " & value)
                    lg.WriteLine("  " & ex.GetType.ToString & " : " & ex.Message)
                    lg.WriteLine("  defaulting to: " & My.Computer.FileSystem.SpecialDirectories.MyDocuments)
                    value = My.Computer.FileSystem.SpecialDirectories.MyDocuments
                End Try
            End If
            _outputFolder = value
            _outputPdfFile = IO.Path.Combine(_outputFolder, _exportFile & ".dxf")
            lg.WriteLine("  outputFolder: " & _outputFolder)
            lg.WriteLine("  outputPdfFile: " & _outputPdfFile)
            lg.WriteLine("exiting Set Property OutputFolder")
            lg.WriteLine("")
        End Set
    End Property
    Private _outputPdfFile As String = ""
    Public Property OutputPdfFileName() As String
        Get
            Return _outputPdfFile
        End Get
            lg.WriteLine("Set Property OutputPdfFileName")
            lg.WriteLine("  value passed to property: " & value)
            _exportFile = IO.Path.GetFileName(value)
            If _exportFile.Substring(_exportFile.Length - 4, 4).ToLower = ".dxf" Then
                'strip off ".dxf" extension
                _exportFile = _exportFile.Substring(_exportFile.Length - 4, 4)
            End If
            lg.WriteLine("  _exportFile: " & _exportFile)
            If Not value.Contains("\") Then
                lg.WriteLine("  does not appear to contain path information")
                'file name only, need to add output path
                _outputPdfFile = IO.Path.Combine(Me.OutputFolder, _exportFile & ".dxf")
            Else
                'value contains path, update _outputFolder
                lg.WriteLine("  value contains path, updating the output folder...")
                lg.WriteLine("  parent path: " & Me.GetParentPath(value))
                Me.OutputFolder = Me.GetParentPath(value)
            End If
            '_outputPdfFile = value
            lg.WriteLine("  outputFolder: " & Me.OutputFolder)
            lg.WriteLine("exiting Set Property OutputPdfFileName")
            lg.WriteLine("")
        End Set
    End Property
    Private _overwritePdf As Boolean = True
    Public Property OverwritePdf() As Boolean
        Get
            Return _overwritePdf
        End Get
            lg.WriteLine("Set Property OverwritePdf")
            _overwritePdf = value
            lg.WriteLine("  overwritePdf: " & _overwritePdf.ToString)
            lg.WriteLine("exiting Set Property OverwritePdf")
            lg.WriteLine("")
        End Set
    End Property
    Private _thePart As Part = Nothing
    Public Property Part() As Part
        Get
            Return _thePart
        End Get
        Set(ByVal value As Part)
            lg.WriteLine("Set Property Part")
            _thePart = value
            _partUnits = _thePart.PartUnits
            Me.GetPartInfo()
            Me.GetDrawingSheets()
            If Me.SortSheetsByName Then
                Me.SortDrawingSheets()
            End If
            lg.WriteLine("exiting Set Property Part")
            lg.WriteLine("")
        End Set
    End Property
    Private _partFilePath As String
    Public ReadOnly Property PartFilePath() As String
        Get
            Return _partFilePath
        End Get
    End Property
    Private _partNumber As String
    Public ReadOnly Property PartNumber() As String
        Get
            Return _partNumber
        End Get
    End Property
    Private _partRevision As String = ""
    Public ReadOnly Property PartRevision() As String
        Get
            Return _partRevision
        End Get
    End Property
    Private _preliminaryPrint As Boolean = False
    Public Property PreliminaryPrint() As Boolean
        Get
            Return _preliminaryPrint
        End Get
            lg.WriteLine("Set Property PreliminaryPrint")
            _preliminaryPrint = value
            If String.IsNullOrEmpty(_exportFile) Then
                'do nothing
            Else
                Me.GetOutputName()
            End If
            lg.WriteLine("  preliminaryPrint: " & _preliminaryPrint.ToString)
            lg.WriteLine("exiting Set Property PreliminaryPrint")
            lg.WriteLine("")
        End Set
    End Property
    Public ReadOnly Property SheetCount() As Integer
        Get
            Return _drawingSheets.Count
        End Get
    End Property
    Private _showConfirmationDialog As Boolean = False
    Public Property ShowConfirmationDialog() As Boolean
        Get
            Return _showConfirmationDialog
        End Get
            _showConfirmationDialog = value
        End Set
    End Property
    Private _skipBlankSheets As Boolean = True
    Public Property SkipBlankSheets() As Boolean
        Get
            Return _skipBlankSheets
        End Get
            _skipBlankSheets = value
        End Set
    End Property
    Private _sortSheetsByName As Boolean
    Public Property SortSheetsByName() As Boolean
        Get
            Return _sortSheetsByName
        End Get
            lg.WriteLine("Set Property SortSheetsByName")
            _sortSheetsByName = value
            If _sortSheetsByName = True Then
                'sort alphabetically by sheet name
            Else
                'get original collection order of sheets
            End If
            lg.WriteLine("  sortSheetsByName: " & _sortSheetsByName.ToString)
            lg.WriteLine("exiting Set Property SortSheetsByName")
            lg.WriteLine("")
        End Set
    End Property
    Private _textAsPolylines As Boolean = False
    Public Property TextAsPolylines() As Boolean
        Get
            Return _textAsPolylines
        End Get
            lg.WriteLine("Set Property TextAsPolylines")
            _textAsPolylines = value
            lg.WriteLine("  textAsPolylines: " & _textAsPolylines.ToString)
            lg.WriteLine("exiting Set Property TextAsPolylines")
            lg.WriteLine("")
        End Set
    End Property
    Private _useWatermark As Boolean = False
    Public Property UseWatermark() As Boolean
        Get
            Return _useWatermark
        End Get
            lg.WriteLine("Set Property UseWatermark")
            _useWatermark = value
            lg.WriteLine("  useWatermark: " & _useWatermark.ToString)
            lg.WriteLine("exiting Set Property UseWatermark")
            lg.WriteLine("")
        End Set
    End Property
    Private _watermarkAddDatestamp As Boolean = True
    Public Property WatermarkAddDatestamp() As Boolean
        Get
            Return _watermarkAddDatestamp
        End Get
            lg.WriteLine("Set Property WatermarkAddDatestamp")
            _watermarkAddDatestamp = value
            lg.WriteLine("  watermarkAddDatestamp: " & _watermarkAddDatestamp.ToString)
            If _watermarkAddDatestamp Then
                'to do: internationalization for dates
                _watermarkTextFinal = _watermarkText & " " & Today
            Else
            End If
            lg.WriteLine("  watermarkTextFinal: " & _watermarkTextFinal)
            lg.WriteLine("exiting Set Property WatermarkAddDatestamp")
            lg.WriteLine("")
        End Set
    End Property
    Private _watermarkText As String = "PRELIMINARY PRINT NOT TO BE USED FOR PRODUCTION"
    Public Property WatermarkText() As String
        Get
            Return _watermarkText
        End Get
            lg.WriteLine("Set Property WatermarkText")
            _watermarkText = value
            lg.WriteLine("  watermarkText: " & _watermarkText)
            lg.WriteLine("exiting Set Property WatermarkText")
            lg.WriteLine("")
        End Set
    End Property
#End Region
#Region "public methods"
    Public Sub New()
        Me.StartLog()
    End Sub
    Public Sub New(ByVal thePart As NXOpen.Part)
        Me.StartLog()
        Me.Part = thePart
    End Sub
    Public Sub PickExportFolder()
        'Requires:
        '    Imports System.IO
        '    Imports System.Windows.Forms
        'if the user presses OK on the dialog box, the chosen path is returned
        'if the user presses cancel on the dialog box, 0 is returned
        lg.WriteLine("Sub PickExportFolder")
        If Me.ExportToTc Then
            lg.WriteLine("  N/A when ExportToTc = True")
            lg.WriteLine("  exiting Sub PickExportFolder")
            lg.WriteLine("")
            Return
        End If
        Dim strLastPath As String
        'Key will show up in HKEY_CURRENT_USER\Software\VB and VBA Program Settings
        Try
            'Get the last path used from the registry
            lg.WriteLine("  attempting to retrieve last export path from registry...")
            strLastPath = GetSetting("NX journal", "Export pdf", "ExportPath")
            'msgbox("Last Path: " & strLastPath)
        Catch e As ArgumentException
            lg.WriteLine("  ** Argument Exception: " & e.Message)
        Catch e As Exception
            lg.WriteLine("  ** Exception type: " & e.GetType.ToString)
            lg.WriteLine("  ** Exception message: " & e.Message)
            'MsgBox(e.GetType.ToString)
        Finally
        End Try
        ' Then use the following code to create the Dialog window
            ' Select the D:\home directory on entry.
            If Directory.Exists(strLastPath) Then
                .SelectedPath = strLastPath
            Else
                .SelectedPath = My.Computer.FileSystem.SpecialDirectories.MyDocuments
            End If
            .Description = "Select the directory to export .dxf file"
                Me.OutputFolder = .SelectedPath
                lg.WriteLine("  selected output path: " & .SelectedPath)
                ' save the output folder path in the registry for use on next run
                SaveSetting("NX journal", "Export pdf", "ExportPath", .SelectedPath)
            Else
                'user pressed 'cancel', keep original value of output folder
                _cancelOutput = True
                Me.OutputFolder = Nothing
                lg.WriteLine("  folder browser dialog cancel button pressed")
                lg.WriteLine("  current output path: {nothing}")
            End If
        End With
        lg.WriteLine("exiting Sub PickExportFolder")
        lg.WriteLine("")
    End Sub
    Public Sub PromptPreliminaryPrint()
        lg.WriteLine("Sub PromptPreliminaryPrint")
            lg.WriteLine("  output canceled")
            Return
        End If
        Dim rspPreliminaryPrint As DialogResult
        rspPreliminaryPrint = MessageBox.Show("Add preliminary print watermark?", "Add Watermark?", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
        If rspPreliminaryPrint = DialogResult.Yes Then
            Me.PreliminaryPrint = True
            lg.WriteLine("  this is a preliminary print")
        Else
            Me.PreliminaryPrint = False
            lg.WriteLine("  this is not a preliminary print")
        End If
        lg.WriteLine("exiting Sub PromptPreliminaryPrint")
        lg.WriteLine("")
    End Sub
    Public Sub PromptWatermarkText()
        lg.WriteLine("Sub PromptWatermarkText")
        lg.WriteLine("  useWatermark: " & Me.UseWatermark.ToString)
        Dim theWatermarkText As String = Me.WatermarkText
        If Me.UseWatermark Then
            theWatermarkText = InputBox("Enter watermark text", "Watermark", theWatermarkText)
            Me.WatermarkText = theWatermarkText
        Else
            lg.WriteLine("  suppressing watermark prompt")
        End If
        lg.WriteLine("exiting Sub PromptWatermarkText")
        lg.WriteLine("")
    End Sub
    Public Sub SortDrawingSheets()
            Return
        End If
        If Not IsNothing(_thePart) Then
            _drawingSheets.Sort(AddressOf Me.CompareSheetNames)
        End If
    End Sub
    Public Sub SortDrawingSheets(ByVal customSortFunction As System.Comparison(Of NXOpen.Drawings.DrawingSheet))
            Return
        End If
            _drawingSheets.Sort(customSortFunction)
        End If
    End Sub
    Public Sub Commit()
            Return
        End If
        lg.WriteLine("Sub Commit")
        lg.WriteLine("  number of drawing sheets in part file: " & _drawingSheets.Count.ToString)
        _outputPdfFiles.Clear()
        For Each tempSheet As Drawings.DrawingSheet In _drawingSheets
            If Me.PreliminaryPrint Then
                _outputPdfFiles.Add(IO.Path.Combine(Me.OutputFolder, tempSheet.Name & "_preliminary.dxf"))
            Else
                _outputPdfFiles.Add(IO.Path.Combine(Me.OutputFolder, tempSheet.Name & ".dxf"))
            End If
        Next
        'make sure we can output to the specified file(s)
        If Me.ExportSheetsIndividually Then
            'check each sheet
            For Each newPdf As String In _outputPdfFiles
                If Not Me.DeleteExistingPdfFile(newPdf) Then
                    If _overwritePdf Then
                        'file could not be deleted
                        MessageBox.Show("The pdf file: " & newPdf & " exists and could not be overwritten." & ControlChars.NewLine & _
                                        "PDF export exiting", "PDF export error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                    Else
                        'file already exists and will not be overwritten
                        MessageBox.Show("The pdf file: " & newPdf & " exists and the overwrite option is set to False." & ControlChars.NewLine & _
                                        "PDF export exiting", "PDF file exists", MessageBoxButtons.OK, MessageBoxIcon.Error)
                    End If
                    Return
                End If
            Next
        Else
            'check _outputPdfFile
            If Not Me.DeleteExistingPdfFile(_outputPdfFile) Then
                    MessageBox.Show("The pdf file: " & _outputPdfFile & " exists and could not be overwritten." & ControlChars.NewLine & _
                Else
                    MessageBox.Show("The pdf file: " & _outputPdfFile & " exists and the overwrite option is set to False." & ControlChars.NewLine & _
                End If
                Return
            End If
        End If
'        Dim sheetCount As Integer = 0
'       Dim sheetsExported As Integer = 0
'        Dim numPlists As Integer = 0
'        Dim myPlists() As Tag
'        _theUfSession.Plist.AskTags(myPlists, numPlists)
'        For i As Integer = 0 To numPlists - 1
'            _theUfSession.Plist.Update(myPlists(i))
'        Next
'        For Each tempSheet As Drawings.DrawingSheet In _drawingSheets
'            sheetCount += 1
'            lg.WriteLine("  working on sheet: " & tempSheet.Name)
'           lg.WriteLine("  sheetCount: " & sheetCount.ToString)
            'update any views that are out of date
'            lg.WriteLine("  updating OutOfDate views on sheet: " & tempSheet.Name)
'            Me.Part.DraftingViews.UpdateViews(Drawings.DraftingViewCollection.ViewUpdateOption.OutOfDate, tempSheet)
'        Next
'        If Me._drawingSheets.Count > 0 Then
'            lg.WriteLine("  done updating views on all sheets")
'            Try
'                If Me.ExportSheetsIndividually Then
'                        lg.WriteLine("  calling Sub ExportPdf")
'                        lg.WriteLine("")
'                        If Me.PreliminaryPrint Then
'                            Me.ExportPdf(tempSheet, IO.Path.Combine(Me.OutputFolder, tempSheet.Name & "_preliminary.dxf"))
'                        Else
'                            Me.ExportPdf(tempSheet, IO.Path.Combine(Me.OutputFolder, tempSheet.Name & ".dxf"))
'                        End If
'                    Next
'                Else
'                    lg.WriteLine("")
'                    Me.ExportPdf()
'                End If
'            Catch ex As Exception
'                lg.WriteLine("  ** error exporting PDF")
'                lg.WriteLine("  " & ex.GetType.ToString & " : " & ex.Message)
                'MessageBox.Show("Error occurred in PDF export" & vbCrLf & ex.Message, "Error exporting PDF", MessageBoxButtons.OK, MessageBoxIcon.Error)
'                Throw ex
'            End Try
'        Else
            'no sheets in file
'            lg.WriteLine("  ** no drawing sheets in file: " & Me._partNumber)
'        End If
        If Me.ShowConfirmationDialog Then
            Me.DisplayConfirmationDialog()
        End If
        If (Not Me.ExportToTc) AndAlso (Me.OpenPdf) AndAlso (Me._drawingSheets.Count > 0) Then
            'open new pdf print
            lg.WriteLine("  trying to open newly created pdf file")
            Try
                        System.Diagnostics.Process.Start(newPdf)
                    Next
                Else
                    System.Diagnostics.Process.Start(Me.OutputPdfFileName)
                End If
                lg.WriteLine("  pdf open process successful")
                lg.WriteLine("  ** error opening pdf **")
            End Try
        End If
        lg.WriteLine("  exiting Sub ExportSheetsToPdf")
        lg.WriteLine("")
    End Sub
#End Region
#Region "private methods"
    Private Sub GetPartInfo()
        lg.WriteLine("Sub GetPartInfo")
        If Me.IsTCRunning Then
            _partNumber = _thePart.GetStringAttribute("DB_PART_NO")
            _partRevision = _thePart.GetStringAttribute("DB_PART_REV")
            lg.WriteLine("  TC running")
            lg.WriteLine("  partNumber: " & _partNumber)
            lg.WriteLine("  partRevision: " & _partRevision)
        Else 'running in native mode
            _partNumber = IO.Path.GetFileNameWithoutExtension(_thePart.FullPath)
            _partFilePath = IO.Directory.GetParent(_thePart.FullPath).ToString
            lg.WriteLine("  Native NX")
            lg.WriteLine("  partFilePath: " & _partFilePath)
            Try
                _partRevision = _thePart.GetStringAttribute("REVISION")
                _partRevision = _partRevision.Trim
                _partRevision = ""
            End Try
        End If
        If String.IsNullOrEmpty(_partRevision) Then
            _exportFile = _partNumber
        Else
            _exportFile = _partNumber & "_" & _partRevision
        End If
        lg.WriteLine("")
        Me.GetOutputName()
        lg.WriteLine("  exportFile: " & _exportFile)
        lg.WriteLine("  exiting Sub GetPartInfo")
        lg.WriteLine("")
    End Sub
    Private Sub GetOutputName()
        lg.WriteLine("Sub GetOutputName")
        _exportFile.Replace("_preliminary", "")
        _exportFile.Replace("_PDF_1", "")
        If IsNothing(Me.Part) Then
            lg.WriteLine("  Me.Part is Nothing")
            lg.WriteLine("  exiting Sub GetOutputName")
            lg.WriteLine("")
            Return
        End If
        If Not IsTCRunning And _preliminaryPrint Then
            _exportFile &= "_preliminary"
        End If
        If Me.ExportToTc Then      'export to Teamcenter dataset
            lg.WriteLine("  export to TC option chosen")
                lg.WriteLine("  TC is running")
                _exportFile &= "_PDF_1"
            Else
                'error, cannot export to a dataset if TC is not running
                lg.WriteLine("  ** error: export to TC option chosen, but TC is not running")
                'todo: throw error
            End If
        Else                    'export to file system
            lg.WriteLine("  export to filesystem option chosen")
                'exporting from TC to filesystem, no part folder to default to
                'default to "MyDocuments" folder
                _outputPdfFile = IO.Path.Combine(My.Computer.FileSystem.SpecialDirectories.MyDocuments, _exportFile & ".dxf")
            Else
                lg.WriteLine("  native NX")
                'exporting from native to file system
                'use part folder as default output folder
                If _outputFolder = "" Then
                    _outputFolder = _partFilePath
                End If
            End If
        End If
        lg.WriteLine("")
    End Sub
    Private Sub GetDrawingSheets()
        _drawingSheets.Clear()
        For Each tempSheet As Drawings.DrawingSheet In _thePart.DrawingSheets
            If _skipBlankSheets Then
                _theUfSession.Disp.SetDisplay(UFConstants.UF_DISP_SUPPRESS_DISPLAY)
                Dim currentSheet As Drawings.DrawingSheet = _thePart.DrawingSheets.CurrentDrawingSheet
                tempSheet.Open()
                If Not IsSheetEmpty(tempSheet) Then
                    _drawingSheets.Add(tempSheet)
                End If
                Try
                    currentSheet.Open()
                    lg.WriteLine("  NX current sheet error: " & ex.Message)
                    lg.WriteLine("  current sheet error: " & ex.Message)
                End Try
                _theUfSession.Disp.SetDisplay(UFConstants.UF_DISP_UNSUPPRESS_DISPLAY)
                _theUfSession.Disp.RegenerateDisplay()
            Else
            End If
        Next
    End Sub
    Private Function CompareSheetNames(ByVal x As Drawings.DrawingSheet, ByVal y As Drawings.DrawingSheet) As Integer
        'case-insensitive sort
        Dim myStringComp As StringComparer = StringComparer.CurrentCultureIgnoreCase
        'for a case-sensitive sort (A-Z then a-z), change the above option to:
        'Dim myStringComp As StringComparer = StringComparer.CurrentCulture
        Return myStringComp.Compare(x.Name, y.Name)
    End Function
    Private Function GetParentPath(ByVal thePath As String) As String
        lg.WriteLine("Function GetParentPath(" & thePath & ")")
        Try
            Dim directoryInfo As System.IO.DirectoryInfo
            directoryInfo = System.IO.Directory.GetParent(thePath)
            lg.WriteLine("  returning: " & directoryInfo.FullName)
            lg.WriteLine("exiting Function GetParentPath")
            lg.WriteLine("")
            Return directoryInfo.FullName
        Catch ex As ArgumentNullException
            lg.WriteLine("  Path is a null reference.")
            Throw ex
        Catch ex As ArgumentException
            lg.WriteLine("  Path is an empty string, contains only white space, or contains invalid characters")
            Throw ex
        End Try
        lg.WriteLine("")
    End Function
    Private Sub ExportPdf()
	Dim theSession As Session = Session.GetSession()
	Dim ufs As UFSession = UFSession.GetUFSession()
	Dim dxfSettingsFile As String
	Dim criticalError As Boolean = False
	Dim lg As LogFile = theSession.LogFile
    Dim dwgs As Drawings.DrawingSheetCollection
    dwgs = workPart.DrawingSheets
    Dim sheet As Drawings.DrawingSheet
    Dim i As Integer = 0
    Dim n As Integer = 0
    Dim tempCGMFile As String
    Dim tempNewFile As String
    Dim dxfFile As String
    Dim currentPath As String
    Dim currentFile As String
    Dim originalFile As String
    Dim originalPart As Part
    Dim killList() As String
    Dim partUnits As Integer
    Dim strOutputFolder As String
    Dim rsp
    Dim strRevision As String
    Dim exportFile As String
    lw.Open()
        'if running Teamcenter, change this to point to your temp import/export dataset file
        Const tempTCDXF = "@DB@123/dwg2dxf@A"
        lg.WriteLine("~ Start of drawing to DXF journal ~")
        'Get UG install directory using NXOpen API
        Dim DXFDWG_DIR As String = theSession.GetEnvironmentVariableValue("DXFDWG_DIR")
        dxfSettingsFile = IO.Path.Combine(DXFDWG_DIR, "dxfdwg.def")
        lg.WriteLine("looking for dxf settings file: " & dxfSettingsFile)
        'check if the dxfSettingsFile exists
        If Not File.Exists(dxfSettingsFile) Then
            'file does not exist in default directory or user specified directory
            lg.WriteLine("The dxf settings file was not found in the specified location: " & dxfSettingsFile)
            MsgBox("The dxf settings file (dxfdwg.def) was not found." & vbCrLf & _
                "This journal will now exit.", vbOKOnly + vbCritical, "Error")
            Exit Sub
        End If
        lg.WriteLine("DXF settings file found: " & dxfSettingsFile)
        'determine if we are running under TC or native
        Dim IsTcEng As Boolean = False
        ufs.UF.IsUgmanagerActive(IsTcEng)
        lg.WriteLine("TC running? " & IsTcEng)
        originalPart = displayPart
        If IsTcEng Then
            lg.WriteLine("tempTCDXF: " & tempTCDXF)
            currentFile = workPart.GetStringAttribute("DB_PART_NO")
            strRevision = workPart.GetStringAttribute("DB_PART_REV")
            originalFile = "@DB/" & currentFile & "/" & strRevision
            currentFile = currentFile.Replace("/", "_")
            currentFile = currentFile & "_" & strRevision
            currentPath = Path.GetDirectoryName(workPart.FullPath)
            currentFile = Path.GetFileNameWithoutExtension(workPart.FullPath)
            originalFile = currentFile
            Try
                strRevision = workPart.GetStringAttribute("REVISION")
                strRevision = Trim(strRevision)
            Catch ex As NXOpen.NXException
                If ex.ErrorCode = 512008 Then
                    lg.WriteLine("Revision attribute not found")
                Else
                    lg.WriteLine("Error: " & ex.ErrorCode & " " & ex.GetType.ToString & " : " & ex.Message)
                End If
                strRevision = ""
            End Try
            If strRevision <> "" Then
            End If
        End If
        exportFile = currentFile
        lg.WriteLine("workPart.FullPath: " & workPart.FullPath)
        lg.WriteLine("currentFile: " & currentFile)
        lg.WriteLine("strRevision: " & strRevision)
        lg.WriteLine("originalFile: " & originalFile)
        lg.WriteLine("originalPart: " & originalPart.FullPath)
        partUnits = workPart.PartUnits
        '0 = inch
        '1 = metric
        lg.WriteLine("Part units: " & workPart.PartUnits.ToString)
            ' Select the C:\ directory on entry.
            .Description = "Select the directory to export .dxf file(s)"
                strOutputFolder = .SelectedPath
            Else
                Exit Sub
            End If
        End With
        lg.WriteLine("Output folder: " & strOutputFolder)
        For Each sheet In dwgs
            i += 1
            'in original file, export each drawing sheet as a .cgm file
            'prepare for CGM export
            tempCGMFile = Path.Combine(strOutputFolder, currentFile & "_" & i & ".cgm")
            lg.WriteLine("Exporting temp CGM file: " & tempCGMFile)
            If File.Exists(tempCGMFile) Then
                lg.WriteLine(tempCGMFile & " already exists, deleting file before export")
                Try
                    File.Delete(tempCGMFile)
                Catch ex As UnauthorizedAccessException
                    lg.WriteLine("Unauthorized access exception, cannot delete file: " & tempCGMFile)
                    lg.WriteLine("Please check permissions on the file and folder(s) and try again")
                    lg.WriteLine("Drawing to DXF journal will now exit")
                    MsgBox("Error: cannot delete file: " & tempCGMFile, MsgBoxStyle.Critical, "Unauthorized access exception")
                    Exit Sub
                Catch ex As ApplicationException
                    lg.WriteLine("Error occurred while attempting to delete file: " & tempCGMFile)
                    lg.WriteLine(ex.GetType.ToString & " : " & ex.Message)
                    MsgBox("Error occurred while attempting to delete file: " & tempCGMFile & vbCrLf & "Drawing to DXF journal will now exit", MsgBoxStyle.Critical, "Error")
                End Try
            End If
            Try
                ExportCGM(sheet, tempCGMFile, partUnits)
                MsgBox("Error occurred in CGM export" & vbCrLf & ex.GetType.ToString & " : " & ex.Message & vbCrLf & "journal exiting", vbCritical + vbOKOnly, "Error")
                lg.WriteLine("Error occurred in CGM export: " & ex.GetType.ToString & " : " & ex.Message)
                Exit Sub
            End Try
            'import .cgm file to temporary file in preparation for .dxf export
            If IsTcEng Then
                Try
                    lg.WriteLine("theSession.Parts.SetNonmasterSeedPartData(" & tempTCDXF & ")")
                    theSession.Parts.SetNonmasterSeedPartData(tempTCDXF)
                    Dim basePart1 As BasePart
                    lg.WriteLine("Opening part: " & tempTCDXF)
                    basePart1 = theSession.Parts.OpenBaseDisplay(tempTCDXF, partLoadStatus1)
                    lg.WriteLine(tempTCDXF & " load status: " & partLoadStatus1.ToString)
                    MsgBox("An error occurred while opening the temp dxf import part" & vbCrLf & ex.GetType.ToString & " : " & ex.Message, vbCritical + vbOKOnly, "Error")
                    lg.WriteLine("An error occurred while opening: " & tempTCDXF & " " & ex.GetType.ToString & " : " & ex.Message)
                    Exit Sub
                Finally
                End Try
            Else
                'create a new file to import the CGM
                tempNewFile = strOutputFolder & "\" & currentFile & "_" & i & ".prt"
                lg.WriteLine("tempNewFile: " & tempNewFile)
                If File.Exists(tempNewFile) Then
                    lg.WriteLine("tempNewFile already exists: " & tempNewFile)
                    rsp = MsgBox("The file: '" & tempNewFile & "' already exists; overwrite?", vbYesNo + vbQuestion, "File exists")
                    If rsp = vbYes Then
                        lg.WriteLine("user has chosen to overwrite: " & tempNewFile)
                        Try
                            lg.WriteLine("attempting to delete: " & tempNewFile)
                            File.Delete(tempNewFile)
                            lg.WriteLine("Unauthorized access exception, check permissions on: " & tempNewFile & " and try again")
                            MsgBox("Unable to delete file: " & tempNewFile & vbCrLf & "Drawing to DXF journal will now exit", MsgBoxStyle.Critical, "Unauthorized Access Exception")
                            Exit Sub
                            lg.WriteLine("An exception occurred while attempting to delete file: " & tempNewFile)
                            MsgBox("An exception occurred while attempting to delete file: " & tempNewFile & vbCrLf & "Drawing to DXF journal will now exit", MsgBoxStyle.Critical, "Error")
                            Exit Sub
                        End Try
                    Else
                        lg.WriteLine("User chose not to overwrite the existing file: " & tempNewFile)
                        MsgBox("journal exiting", vbOKOnly, "Export cancelled")
                        Exit Sub
                    End If
                End If
                Try
                    lg.WriteLine("Attempting to create temporary cgm import file: " & tempNewFile)
                    NewFile(tempNewFile, partUnits)
                    lg.WriteLine("Error in temporary cgm import file creation: " & tempNewFile)
                    MsgBox("Error occurred in new file creation" & vbCrLf & ex.Message & vbCrLf & "journal exiting", vbCritical + vbOKOnly, "Error")
                    Exit Sub
                End Try
            End If
            'now in temporary dxf import file
            lg.WriteLine("work part: " & theSession.Parts.Work.FullPath)
            'turn off the display of the drawing sheet, some users report errors if the sheet is displayed when the view is replaced
            '1 = Modeling view
            '2 = Drawing view
            ufs.Draw.SetDisplayState(1)
            'replace view to "TOP" before importing the CGM
            'this gives better results with fixed view drawing viewers such as edrawings
            Dim layout1 As Layout = CType(theSession.Parts.Work.Layouts.Current, Layout)
            lg.WriteLine("current layout: " & layout1.Name)
            Dim modelingView1 As ModelingView = CType(theSession.Parts.Work.ModelingViews.FindObject("TOP"), ModelingView)
            lg.WriteLine("modelingView1: " & modelingView1.Name)
            layout1.ReplaceView(theSession.Parts.Work.ModelingViews.WorkView, modelingView1, True)
            'Call the ImportCGM subroutine
            workPart.Layers.WorkLayer = 1
            lg.WriteLine("Calling the ImportCGM(" & tempCGMFile & ")")
            ImportCGM(tempCGMFile)
            lg.WriteLine("Saving temporary cgm import file: " & tempCGMFile)
            workPart.Save(BasePart.SaveComponents.False, BasePart.CloseAfterSave.False)
            If IsTcEng Then
                ReDim Preserve killList(i)
                killList(i) = tempCGMFile
                lg.WriteLine("Adding file to kill list: " & tempCGMFile)
            Else
                'add the temp files to the kill list
                ReDim Preserve killList(i * 2)
                killList(i * 2 - 1) = tempCGMFile
                killList(i * 2) = tempNewFile
                lg.WriteLine("Adding file to kill list: " & tempNewFile)
            End If
            dxfFile = Path.Combine(strOutputFolder, currentFile & "_" & i & ".dxf")
            lg.WriteLine("DXF file: " & dxfFile)
            If File.Exists(dxfFile) Then
                rsp = MsgBox("The file: '" & dxfFile & "' already exists; overwrite?", vbYesNo + vbQuestion, "File exists")
                lg.WriteLine("The specified DXF output file already exists")
                If rsp = vbYes Then
                    lg.WriteLine("user has chosen to overwrite the existing DXF file")
                    Try
                        File.Delete(dxfFile)
                        lg.WriteLine("Unauthorized access exception, cannot delete file: " & dxfFile)
                        MsgBox("Error: cannot delete file: " & dxfFile & vbCrLf & "Please check permissions on the file and try again", MsgBoxStyle.Critical, "Unauthorized access exception")
                        Exit Sub
                        lg.WriteLine("Error occurred while attempting to delete file: " & dxfFile)
                        MsgBox("Error occurred while attempting to delete file: " & dxfFile & vbCrLf & "Drawing to DXF journal will now exit", MsgBoxStyle.Critical, "Error")
                    End Try
                Else
                    lg.WriteLine("user chose not to overwrite existing DXF file")
                    MsgBox("Journal will now exit", MsgBoxStyle.Exclamation, "Export cancelled")
                    Exit Sub
                End If
            End If
            Try
                'Call ExportDXF subroutine
                lg.WriteLine("Calling export DXF routine")
                If IsTcEng Then
                    lg.WriteLine("ExportDXF(" & tempTCDXF & ", " & dxfFile & ")")
                    ExportDXF(tempTCDXF, dxfFile)
                Else
                    lg.WriteLine("ExportDXF(" & tempNewFile & ", " & dxfFile & ")")
                    ExportDXF(tempNewFile, dxfFile)
                End If
                lg.WriteLine("Waiting on creation of DXF file...")
                While Not File.Exists(dxfFile)
                    Application.DoEvents()
                End While
                lg.WriteLine("DXF file created: " & dxfFile)
                MsgBox("Error occurred in DXF export" & vbCrLf & ex.Message & vbCrLf & "journal exiting", vbCritical + vbOKOnly, "Error")
                lg.WriteLine("Error in DXF export: " & ex.GetType.ToString & " : " & ex.Message)
                Exit Sub
            Finally
                lg.WriteLine("deleting temporary objects from: " & workPart.FullPath)
                Dim markId1 As Session.UndoMarkId
                markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Start")
                'delete all imported objects (all objects on layer 1)
                Dim importEntities() As NXObject
                importEntities = workPart.Layers.GetAllObjectsOnLayer(1)
                Dim nErrs1 As Integer
                nErrs1 = theSession.UpdateManager.AddToDeleteList(importEntities)
                Dim nErrs2 As Integer
                nErrs2 = theSession.UpdateManager.DoUpdate(markId1)
                'close the temporary DXF file
                lg.WriteLine("Closing the temporary dxf file")
                workPart.Save(BasePart.SaveComponents.False, BasePart.CloseAfterSave.True)
            End Try
            'make the original part the displayed part
            Dim partLoadStatus2 As PartLoadStatus
            status1 = theSession.Parts.SetDisplay(originalPart, False, True, partLoadStatus2)
            lg.WriteLine("make original part the displayed part")
            lg.WriteLine("status1: " & status1.ToString)
            partLoadStatus2.Dispose()
            lg.WriteLine("current display part: " & displayPart.FullPath)
        Next
        If i = 0 Then
            lg.WriteLine("This part has no drawing sheets to export")
            MsgBox("This part has no drawing sheets to export", MsgBoxStyle.Exclamation, "Huh?")
        Else
            'cleanup temp files
            lg.WriteLine("Cleaning up temporary files")
            Dim j As Integer
            j = 1
            If IsTcEng Then
                For j = 1 To i
                    File.Delete(killList(j))
                    lg.WriteLine("File deleted: " & killList(j))
                Next
            Else
                For j = 1 To i * 2
                Next
            End If
            MsgBox("Exported: " & i & " sheets as dxf files", vbOKOnly + vbInformation, "Success!")
            lg.WriteLine("Exported: " & i & " sheets as dxf files")
        End If
        lg.WriteLine("~ End of drawing to DXF export journal ~")
        lw.Close()
    End Sub
    Sub ExportCGM(ByVal dwg As Drawings.DrawingSheet, ByVal outputFile As String, ByVal units As Integer)
        Dim filenames1(0) As String
        Dim objCGM As CGMBuilder
        objCGM = theSession.Parts.Work.PlotManager.CreateCgmBuilder()
        objCGM.Action = CGMBuilder.ActionOption.FileBrowser
        objCGM.OutputText = CGMBuilder.OutputTextOption.Polylines
        If units = 0 Then
            objCGM.Units = CGMBuilder.UnitsOption.English
        Else
            objCGM.Units = CGMBuilder.UnitsOption.Metric
        End If
        objCGM.XDimension = dwg.Height
        objCGM.YDimension = dwg.Length
        objCGM.VdcCoordinates = CGMBuilder.Vdc.Real
        objCGM.RasterImages = True
        Dim sheets1(0) As NXObject
        sheets1(0) = dwg
        objCGM.SourceBuilder.SetSheets(sheets1)
        filenames1(0) = outputFile
        objCGM.SetFilenames(filenames1)
        Try
            Dim nXObject1 As NXObject
            nXObject1 = objCGM.Commit()
            lg.WriteLine("Error in ExportCGM subroutine: " & ex.GetType.ToString & " : " & ex.Message)
        Finally
            objCGM.Destroy()
        End Try
    End Sub
the 2 journals you've referenced, only export all the drawing sheets from the displayed drawing part file, they won't search through a folder for drawing files to export, as you seem to be suggesting.
Dear moog3,
If you try running the code in the PDF export journal, you will see it requires you to choose the folder with prt files inside first, then the destination export folder. It actually exports all the files inside the first folder mentioned.
Moreover, like I said, I have tried the code above already. It did scan all the files in the folder I choose. The problem here is that it did not export anything at all. Sad.
Do you see any problems? Please let me know.
Thank you.
You do know that there is an included standalone translator that can take directories as an input ?
Tomas
The more you know about a subject, the more you know how little you know about that subject.
Dear Tomas,
You mean the translator DXFDWG of NX, right? I have tried it already but nothing happens except a notification in the command window (attached picture).
Can you check it for me to see if it is an error or I missed any steps?
Thank you,
Hao
Was the DXF file created? If so, try opening it in notepad (DXF files are text files) to see if anything was written to the file. Are there any errors or warnings in the log file (E:\Desktop\2D\2Z-957#103.log)?
www.nxjournaling.com
Dear cowski,
There is nothing created in the destination folder (E:\Desktop\2D). After choosing the input file and the destination folder, I clicked on the lightning symbol in the middle of the box, and I then received the screen as posted. I tried to wait but nothing happened then.
Additional information: At first, I did not have Java in my PC to run it, so I downloaded the latest Java version on its website and just simply installed it right then but nothing more.
Could you guide me how to use it, please?
Thank you,
Hao
This is how it looks when I open the translator. I chose Export and followed the steps mentioned above. Unlucky nothing transpired, even when I chose Import.
Dear cowski,
The answer is yes. I used those files to export to PDF then publish to my customers. I just use them as some typical samples.
However, I will try with other prt files from other projects to figure out hopefully I am wrong or not.
If the translator works properly, I will receive DXF/DWG files in the destination folder right after I click the lightning symbol?
Thank you,
Hao
Yes, the DXF files should show up in the destination folder once the translation completes. A log file should be created whether or not the translation was successful.
Dear cowski,
I don't know, there should be a log file, as you said, and as usual, when exporting DXFDWG successfully. The issue here is that it broke, so that no either file was created.
How about the code above, is it possible to combine them?
I tried my best to modify it and it did scan all the files in the folder (return an information box). There is one last step to make the journal export DXFDWG each of them, I believe.
Could you quick troubleshoot it for me, please?
Thank you,
Hao
