Hey everyone, first of all --- great website, long time lurker, first time poster. Thanks to all who contribute.
I have a National Instruments data acquisition device and a 900Mhz serial modem being powered by two 12V gel batteries in series. The DAQ and RF modem are in a NEMA rated enclosure and the power is brought in with a marine grade 3 prong plug/receptacle. There is a switch between the receptacle and the devices themselves. The issue I have been having is the RF modem has been intermittently failing. Inspection of the devices shows no evidence of physical damage or burned smell. The failures do not occur at any specific time (ie during battery change) or seem to follow any pattern. The OEM inspection of the failed device claims overvoltage destroyed the device. The device accepts a range of 7-28VDC, two 12V batteries at full charge should check in at around 25.5V. There has never been a failure immediately following a battery change which would stand out to me as the only way to potentially ever have an overvoltage condition but still unlikely. The DAQ accepts 11-30V and has never failed. The application has substantial intermittent impact and vibration. Both devices receive power in similar way with the ground at the receptacle and the positive coming off the fuse block. The RF device is a typical size N radio plug for power while the DAQ is a screw type terminal. What could possibly be happening to cause an overvoltage condition for that device? Is it purely happenstance that the DAQ has never failed in that same manner or perhaps the circuitry inside the device has more protection for such conditions? Is it a bad assumption to think that the voltage of a gel battery is stable even under harsh conditions? My plan at this point is to power the system via 12V to give the device a bit more of a cushion but I'm not answering the true question nor do I think that is really the cause. Perhaps you electrical gurus can help a mechanical guy stumble through this?
