We have need for a software package that will place beam calcs and the moment/shear/deflection results on a single sheet. It needs to do channels also.
Does anyone know of software that will do this. RAM Beam does not.
I don't know how complex a structure you need, but look into Enercalc. It's more for componenet design, not full structures, but it does print output similar to what you're asking for.
Try RISA 2D - you can model most any shape and there is a "Detail" sheet output of each member that shows shear, moment, deflection, axial diagrams along with relevent design criteria and results.
We use STAAD.beam. It seems to be very powerful and does composite beams, checks for vibrations, considers web holes and gives a full detailed set of calculation sheets that shows you how they did the design. We bought an entire site license for like $500 so it was cheap as well.
