Gus14
- Mar 21, 2020
- 194
In the attached file, over the highlighted joints, the beams show weird-looking moment diagrams. Is the software assuming continuity between the beam and the slab sections? I have found the same with trying different models that have similar joints. I don't find this reasonable, and is there a way to stop that in the software?
Sidenotes:
1. This is not the final design beams, columns and slabs will get stiffer.
2. I don't trust CSI safe beams' designs in general and will redo the design of the beams manually. I am currently just learning the software.
Sketch:
Sidenotes:
Sketch:
