1
- #1
Szubert80
- Dec 11, 2013
- 19
Hi All,
I have a roof framing plan attached to this post where you can see W16x26 beam to be framed into continuous W18x40 using moment connection(95kNm).
How would you design a moment connection in this scenerio. The main issue I`m having is how to transfer the moment through a beam`s weak axis into the column cap plate.
Provided that web stiffeners will be designed adequately to transfer the load into the bottom flange of W18 then the challenging part is the connection between bottom flange and cap plate.
I don`t know if there is any other way to make it feasible other than split the continuous beam and frame all 3 beams directly into the column. The beam was designed as continuous due to the fact that it cantilevers 12ft at one end.
Any suggestions would be greatly appreciated.
