CSFlanagan:
To add some confusion and complication to the actual math and physics problem, the real consideration is that you want to absorb a bunch of impact energy if an accidental loading does happen. And you would prefer not to destroy the primary stl. structure in the accidental loading. You really haven’t described your problem very well. I would want to know much more about the whole operating situation and the general plant layout, the various structural components, etc., before doing any design. Can the distance btwn. the top of the stl. bms. and the bottom of the basket be more than 1’? What is the structure of the underside of the basket made up of? Can you/they control the orientation of the basket and its height above the stl. frames pretty well? Does the loaded basket only cross the walkway at 2 or 3 discreet 10’ wide machine locations in the 60’ walkway width? The 60’ walkway width and the 30’ bm. span would seem to indicate that there are three of the moment frames show in your sketch, and 30’ beam spans (beams shown in x-section in your sketch), correct? You better pay close attention to the stability of this whole framing system, since you may have the gravity loading and some lateral basket loading in an accident. Then, you will have a number of basket locations which are worst conditions for various walkway framing members; single 30’ bm. with full loading at mid-span, multiple bms. sharing this load, basket over mid-pt. of moment frame, basket over one frame column, etc.
I’m not sure I see this as an ethical engineering problem. It seems that the client needs good, sound advice on a difficult operating dilemma, and that they are trying to come to a safe and reasonable design for the operating conditions. And, I would review your design solution with the local OSHA people. I think that the OSHA section that SRE cites is to cover general crane lifting operations in a plant or on a job site. Even these lifts should be planned w.r.t. various safety considerations, rigging, etc, but there are people milling allover the plant floor or job site, without an overhead protection system, and they should be protected and/or avoided by the crane operator and lift supervisor. There is plenty of dangerous equip. that people work around and under every day, but not without some special thought and planning or protection. Heck, we don’t keep people out from under the RR overpass every time a train passes over, but the bridge is designed for this, as the client is trying to do here for his situation.
This is not an easy problem when you (or your client) expect an exact, closed form, solution. That’s why much of what you have read suggests much testing and/or crash testing to start to hone-in on an inexact approx. solution. The Physics and Engineering Mechanics we learned in school aren’t wrong, it is just that we can’t nail down all the all-important variables. So, sometimes the best approach is to explain the complexity of the problem (and math complexities) at about a 9th grade level, or early high school physics level and then to bracket the problem with some reasonable assumptions to show a practical range of solutions. Don’t forget, when you look at your deflection to determine your ‘IF’, the beam will deflect due to the loading, but so will the moment frames, so your deflection is low by ~50%.
One simple energy absorbing solution is as follows: put 4x4 wooden timbers perpendicular to the 30’ beams, every 3-4’ o/c, for load distrib. and elevation ; on top of these put a second lay of 4x4’s centered over the 30’ bms.; spike this gridwork of 4x4’s together, and bolt to the stl. bms. Then, I would want the basket to have two bottom skids 9’ long, about 3-4’ apart and perpendicular to the 30’ long bms. I want these skids to break some timbers in the upper layer, over the timbers in the lower layer, thus absorbing energy and distributing/reducing the impact loading to the stl. structure below. Beyond your bracketing calcs., etc., you could fairly simply do some testing on this timber cribbing on a couple bms. to start to show some range of agreement with your calcs.
