ruane
- Nov 6, 2018
- 3
Good day all
I've got a question which is a bit difficult to formulate and hopefully isn't stupid, but here goes...
If I have two beams that join at an angle in plan, can I transfer moment between them where they join? Say for example I have two beams each supporting a floor load that join at a point which is unsupported. Seen in plan the angle between beams is 110 degrees. Will there be moment transfer between the beams at the point where they join? In my head I can't see how the forces will "change direction". If you have a straight beam and you imagine the forces at midspan, they run straight from one beam to another. A straight beam (two pieces joined at 180 degrees) can be simply supported and loaded. If you try and simply support two beams joined at an angle (without torsional restraint at the support) they would just fall of the supports.
My question is: to what degree can transferring of moment between beams at an angle (in plan) with concrete and steel actually be done.
Is there an angle where the bending moment at "midspan" (the point where the tow beams meet) is so unreliable that the beams should be cantilevers fixed at the support or have sufficient torsional restraint.
I've attached a sketch. The angle isn't drawn correctly - it should look more like 90 degrees.
Thanks all
Thanks all
