ajr78
- Sep 15, 2021
- 1
Hi, I am after basic rule for diametrical bearing clearance on a white metal plain bearing lubricated with grease.
I am aware of basic rules (1.5 mil per inch of shaft) for oil lubrication that give a clearance of around 0.34 mm or 0.013". I do not know if similar such rule for grease lubrication exists?
The actual bearing is on a vertical shaft of 230 mm (9") rotating at 150 RPM. It is around 450 mm or 18" long. The grease is an ISO 100 -150 cST at 40 deg C. Radial load is estimated at a maximum of 19 kN giving a bearing average pressure of 0.18 N/mm2 or 26 psi.
