SGEngineer
- Mar 20, 2006
- 12
I'm involved in a project whereby I'm trying to determine appropriate ball bearings for my design. Here's how it works:
The bearings are spaced evenly in a radial manner and are "squeezed" between a tube ID and a rod OD. The bearings preload establish good contact and prevent slipping while the rod is actuating.
The parts are of 63 microinch Ra and of hardened 440C SST HRc 58.
I've got a few questions on this topic.
1. What would be a good interference to preload the bearings so that they don't slip?
2. How do I establish the formula for relating preload to interference?
3. How much preload is required so as not to create any sliding effect on the bearings?
