I have a bearing plate design example that I follow. I often come up with plate thicknesses exceeding 1", as a result of both the load and the beam shape "k1" value.
If the flange width of the beam exceeds the maximum possible plate width, I see no reason to have the plate thickness exceed 3/8" or just enough to have threaded anchors shop welded to the top, since there will be no cantilever bending.
What are your thoughts?
Thank you!
Thank you!
