So, I'm looking at creating a press JIG to insert small bushes. I'm going to simply make an adapter to fit onto the end of one of my off-the-shelf toggle presses. My adapter is in essence an 8mm diameter shaft (for simplified purposes)that I would really like to constrained in the vertical axis using bearings.
I'm just curious about what bearings would be the most effective in this case.
Would really appreciate anyone's input!
Thanks!
Thanks!
