beginner tooling and clear-coat help
ummm
Materials
Mar 28, 2003
1
0
0
I'm brand new to carbon fiber. I'm trying to produce a 2-3mm thick plate using an epoxy resin and woven carbon fiber reinforcement. I intend to use a "wet-lay" process and would like a high-gloss clear finish. Can I just use the epoxy as the clear coat or do I need an actual "gelcoat?" Is glass a good non-stick surface to use or is there something better? Any help would be greatly apreciated. Thanks
Depending on why you are making this part, it would be wise to use a supplier that does this day in and day out. I make parts like this for many different business areas and I use autoclaves and presses to get the finish required. See composiflex.com
If you want to do it your self, it can be like wood working if you want a smooth cloth finish. Use neat resins and keep sanding and applying. Use a polished steel sheet which you can get from a industrial metals supplier or use a polyethylene sheet if you want to go cheap. The polyethylene will not stick to the part, the steel sheet needs to have a release applied to it. See De-comp. See web sites like Northern Fiber Glass Sales NFGSales.com. You need to talk to one of their sales people.
Larry
Sounds like you are just doing some experimenting :) For some comprehensive and free information go to and download their 69 page applications pdf. The glossy surface you desire is only obtainable if the surface of your mold is glossy and perfect. As lflex says, polished steel or similar. I can't see a problem with using glass but put some release on it to make sure the part comes off. Heres a good amateur page with some low cost tips on bagging an so forth Don't forget that there are several styles of woven carbon cloth and some are easier than othes to achieve the attractive "carbon" look with. Good luck!
Ben Roberts. Ben Roberts
Broadcast Engineer
Sentient being.
