  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Being gaslighted by a boss--need some opinions. 1
Nabrxx
Industrial
Nov 21, 2011
10
0
0
Hello all,
Our plant leader here is telling us we need to circulate water (chilled and condenser) through all of our machines for 1 hour per barrel, per day.. We have a 12,000 ton plant and this takes 6 hours a night. He says this is required by NYC code. I can't find the code. While I realize that circulating water once a week or so is appropriate to reduce legionella liklihood ...but every night?
Next, He's telling us that we need to rotate every machine in the plant oneline and run for 2 hours per week in order to 'exercise' them during the winter. We have 7 chillers in the plant, 2 electric drive centrifugal and the rest are steam turbines. Again, he says this is a requirement, this time by the manufacturer. Is he crazy?
Inquiring minds want to know.
@mintjulep—sounds like the way to go. I knew I wasn’t crazy. I’ll just comply and sit back and wait😂
Any other comments welcome👍
It's only a hill (to die on or otherwise) if this choice is unsafe. Seems like these practices are safer, not less safe.
Otherwise it's a potential opportunity for operational cost savings. Prioritize accordingly.
It's definitely wise to confirm the legal requirements. If you don't see these in the regs, maybe the regs now say to do something else entirely? Compliance is always worth a double-check.
David
It may seem safer, but consider the ramifications of constantly putting a well running plant into transition mode to bring on another chiller in order to exercise it. This activity also impacts our boiler plant who must be prepared to supply the needed steam for a turbine to run. It all seems like busy work with critical chilled water temps out at risk unnecessarily. Just asking—it is what it is—I’ve been playing this game for awhile now👍
Is this a requirement? Curious mimes want to know. It's also a waste of resources.
Having watched Louis Rossmann and his travails with NYC, I don't doubt someone in government told the boss something. Louis was faced with a more than $1M tax bill as the NYC government forgot he had ever paid any taxes.
Get out. Save yourself.
What Greg said. Also worth noting regarding maintenance is that best practices often exceed minimum regulatory or warranty requirements. You could propose a cost-reduction project if you believe your plant's processes arent worth the cost-benefit tradeoff, but may discover that the study has been done and current practice is best.
I agree with Greg; I'd just add one thing: get it in writing. This way the boss can't throw you under the bus if boss' boss thinks it is a waste of time/money.
