Bellows in Bellows Sealed Nuclear Class Valve to ASTM A/B or ASME SA/SB?
johcatrac
43
Clauses NX-3515 in ASME III indicates bellows need not constructed to the requirements of the subsection if the bellows does not retain pressure and Design Pressure
is imposed on a required backup stem seal such as packing. But, a bellows in a bellows sealed valve is always retaining pressure - it is either seeing the upstream pressure or the downstream pressure. A reputed valve vendor supplied us the bellows material in ASTM B and when asked the question they reluctantly have agreed to change to ASME SB.
Does anyone on this forum have any insight into this?
Depends on your application and where the bellow in question is used. Show the valve (and its bellows seal location around the stem ???)
