aggman
- Jun 9, 2003
- 253
I have been asked to design some standard truss parallel chord frames, with allowable spans for particular belt widths. The trusses are to carry limestone and coal, and are to be designed to support all the bells and whistles, (walkways, hoods, idlers, pull-stops, and electrical). My question is as follows. Normally I have engineered conveyors for a specific application. This means that the TPH and the pulley resultant loads are known. For the standard truss designs these properties are not known. I have found a previous engineers calcs for similar work and all that he did was design the truss for a uniform moment of 1/8 wl^2, due to the distributed load. While I would agree that would give you the worst case chord force, I am not sure that the loadings are really ideal. He used a surcharged belt with 20psf on the walkway, but of course had no way to account for the compression in the truss due to the conveyor drives. Is this a good way to design the truss, since the likelyhood of a surcharged belt and a 20psf walkway load all happening at once is somewhat unlikely? If not what would you recommend? Thanks in advance for your help.
