Bend Deduction Drawing Link
captainhog
I work for a fabrication shop where we generate our sheet metal parts using a list of deductions we have compiled through bending and measuring parts of various thickness and material type. This requires me to enter the bend deduction for every part I draw and the chance for error when doing this for large assemblies seems very high. Now I know a bend table would be ideal for this situation but my boss fears change and does not want us to create one.
Now for each of our drawings we create a note that states our deduction (i.e. DEDUCTION = .238) which helps verify if the deduction in correct but it does not reference the deduction of the part. Is there a way to link bend deduction used in the part to a property that I can reference in the drawing. I am looking for something similar to the way I would call out thickness if I wanted a material thickness note (Thicknes = "SW-Thickness@blah.sldprt")
Hopefully there is a way to do this or someone has created an API that would be able to accomplish this.
I looked for the variable for bend deduction but find no way to link it directly. A macro can be used to add a Bend deduction property in the part with vale and then that can be linked in drawing via note.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
Look for this "Get All Sheet Metal Feature Data Example (VB6)" under API help. Modify it to set the Bend Deduction property in part.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
I appreciate your responses, they have definitely pointed me in what I believe is the right direction. I tried to use and modify the getallsheetmetal example but the vanilla version of that script does not compile. Has anyone else had any luck with getting this to compile?
The example in the SW API help has some bugs. This is a fixed one which worked for me.
Code:
' Preconditions: Sheet metal part is open.
' Postconditions: None
Option Explicit
Sub Process_CustomBendAllowance(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swCustBend As SldWorks.CustomBendAllowance)
    Debug.Print "      BendAllowance    = " & swCustBend.BendAllowance * 1000# & " mm"
    Debug.Print "      BendDeduction    = " & swCustBend.BendDeduction * 1000# & " mm"
    Debug.Print "      BendTableFile    = " & swCustBend.BendTableFile
    Debug.Print "      KFactor          = " & swCustBend.KFactor
    Debug.Print "      Type             = " & swCustBend.Type
End Sub
Sub Process_SMBaseFlange(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Debug.Print "  +" & swFeat.Name & " [" & swFeat.GetTypeName & "]"
    Dim swBaseFlange                As SldWorks.BaseFlangeFeatureData
    Set swBaseFlange = swFeat.GetDefinition
    Debug.Print "    BendRadius = " & swBaseFlange.BendRadius * 1000# & " mm"
End Sub
Sub Process_SheetMetal(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swCustBend As SldWorks.CustomBendAllowance
    Dim swSheetMetal  As SldWorks.SheetMetalFeatureData
    Set swSheetMetal = swFeat.GetDefinition
    Set swCustBend = swSheetMetal.GetCustomBendAllowance
    Debug.Print "    BendRadius = " & swSheetMetal.BendRadius * 1000# & " mm"
    Process_CustomBendAllowance swApp, swModel, swCustBend
End Sub
Sub Process_SM3dBend(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swSketchBend As SldWorks.SketchedBendFeatureData
    Set swSketchBend = swFeat.GetDefinition
    Set swCustBend = swSketchBend.GetCustomBendAllowance
    Debug.Print "    UseDefaultBendAllowance = " & swSketchBend.UseDefaultBendAllowance
    Debug.Print "    UseDefaultBendRadius = " & swSketchBend.UseDefaultBendRadius
    Debug.Print "    BendRadius = " & swSketchBend.BendRadius * 1000# & " mm"
End Sub
Sub Process_SMMiteredFlange(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swMiterFlange As SldWorks.MiterFlangeFeatureData
    Set swMiterFlange = swFeat.GetDefinition
    Debug.Print "    UseDefaultBendAllowance = " & swMiterFlange.UseDefaultBendAllowance
    Debug.Print "    UseDefaultBendRadius = " & swMiterFlange.UseDefaultBendRadius
    Debug.Print "    BendRadius = " & swMiterFlange.BendRadius * 1000# & " mm"
End Sub
Sub Process_Bends(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swBends As SldWorks.BendsFeatureData)
    Set swCustBend = swBends.GetCustomBendAllowance
    Debug.Print "    BendRadius                 = " & swBends.BendRadius * 1000# & " mm"
    Debug.Print "    UseDefaultBendAllowance    = " & swBends.UseDefaultBendAllowance
    Debug.Print "    UseDefaultBendRadius       = " & swBends.UseDefaultBendRadius
End Sub
Sub Process_ProcessBends(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swBends                     As SldWorks.BendsFeatureData
    Set swBends = swFeat.GetDefinition
    Process_Bends swApp, swModel, swBends
End Sub
Sub Process_FlattenBends(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
End Sub
Sub Process_EdgeFlange(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swEdgeFlange                As SldWorks.EdgeFlangeFeatureData
    Set swEdgeFlange = swFeat.GetDefinition
    Debug.Print "    UseDefaultBendRadius = " & swEdgeFlange.UseDefaultBendRadius
    Debug.Print "    BendRadius = " & swEdgeFlange.BendRadius * 1000# & " mm"
End Sub
Sub Process_FlatPattern(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swFlatPatt                  As SldWorks.FlatPatternFeatureData
    Set swFlatPatt = swFeat.GetDefinition
    Debug.Print "    To do..."
End Sub
Sub Process_Hem(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swHem                       As SldWorks.HemFeatureData
    Set swHem = swFeat.GetDefinition
    Set swCustBend = swHem.GetCustomBendAllowance
    Debug.Print "    UseDefaultBendAllowance = " & swHem.UseDefaultBendAllowance
    Debug.Print "    Radius = " & swHem.Radius * 1000# & " mm"
End Sub
Sub Process_Jog(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swJog                       As SldWorks.JogFeatureData
    Set swJog = swFeat.GetDefinition
    Set swCustBend = swJog.GetCustomBendAllowance
    Debug.Print "    UseDefaultBendAllowance = " & swJog.UseDefaultBendAllowance
    Debug.Print "    UseDefaultBendRadius = " & swJog.UseDefaultBendRadius
    Debug.Print "    BendRadius = " & swJog.BendRadius * 1000# & " mm"
End Sub
Sub Process_LoftedBend(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swLoftBend                  As SldWorks.LoftedBendsFeatureData
    Set swLoftBend = swFeat.GetDefinition
End Sub
Sub Process_Rip(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swRip                       As SldWorks.RipFeatureData
    Set swRip = swFeat.GetDefinition
End Sub
Sub Process_CornerFeat(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swCloseCorner               As SldWorks.ClosedCornerFeatureData
    Set swCloseCorner = swFeat.GetDefinition
End Sub
Sub Process_OneBend(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swFeat As SldWorks.Feature)
    Dim swOneBend  As SldWorks.OneBendFeatureData
    Set swOneBend = swFeat.GetDefinition
    Set swCustBend = swOneBend.GetCustomBendAllowance
    Debug.Print "      UseDefaultBendAllowance = " & swOneBend.UseDefaultBendAllowance
    Debug.Print "      UseDefaultBendRadius = " & swOneBend.UseDefaultBendRadius
End Sub
Sub main()
    Dim swApp                       As SldWorks.SldWorks
    Dim swModel                     As SldWorks.ModelDoc2
    Dim swSelMgr                    As SldWorks.SelectionMgr
    Dim swFeat                      As SldWorks.Feature
    Dim swSubFeat                   As SldWorks.Feature
    Dim bRet                        As Boolean
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swSelMgr = swModel.SelectionManager
    Set swFeat = swModel.FirstFeature
    Debug.Print "File = " & swModel.GetPathName
    Do While Not swFeat Is Nothing
        ' Process top-level sheet metal features
        Select Case swFeat.GetTypeName
            Case "SMBaseFlange"
                Process_SMBaseFlange swApp, swModel, swFeat
            Case "SheetMetal"
                Process_SheetMetal swApp, swModel, swFeat
            Case "SM3dBend"
                Process_SM3dBend swApp, swModel, swFeat
            Case "SMMiteredFlange"
                Process_SMMiteredFlange swApp, swModel, swFeat
            Case "ProcessBends"
                Process_ProcessBends swApp, swModel, swFeat
            Case "FlattenBends"
                Process_FlattenBends swApp, swModel, swFeat
            Case "EdgeFlange"
                Process_EdgeFlange swApp, swModel, swFeat
            Case "FlatPattern"
                Process_FlatPattern swApp, swModel, swFeat
            Case "Hem"
                Process_Hem swApp, swModel, swFeat
            Case "Jog"
                Process_Jog swApp, swModel, swFeat
            Case "LoftedBend"
                Process_LoftedBend swApp, swModel, swFeat
            Case "Rip"
                Process_Rip swApp, swModel, swFeat
            Case "CornerFeat"
                Process_CornerFeat swApp, swModel, swFeat
            Case Else
                ' Probably not a sheet metal feature
        End Select
        ' process sheet metal sub-features
        Set swSubFeat = swFeat.GetFirstSubFeature
        Do While Not swSubFeat Is Nothing
            Select Case swSubFeat.GetTypeName
                Case "OneBend"
                    Process_OneBend swApp, swModel, swSubFeat
                Case Else
            End Select
            Set swSubFeat = swSubFeat.GetNextSubFeature()
        Loop
        Set swFeat = swFeat.GetNextFeature
    Loop
End Sub
Great, it can be modified now for setting up the property.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
