Bend radius
LACHANDARA
12
Im new to sheet metal, what is the recomended inside bend radius for 6mm stainless steel.
As a general rule of thumb, 1 X material thickness for the inside bend radius is acceptable. On thicker, less ductile material 1.5 X thickness is often preferred.
Rules of thumb differ just as thumbs differ. I agree that a good guide for sheet metal is to use an IBR (inside bend radius) no less than the material thickness and preferably closer to 1.5x thickness, especially for thicker materials (over .100", 2.5mm).
However, the IBR specified is meaningless if the fabricator doesn't have it. Therefore if you plan to use IBR=t but the fabricator doesn't have that size you could get a surprise. It is always good to talk with your fabricator. He (she) will help you be successful.
For general designs you might look up the standard nose radii commonly available and then pick a size that is => t.
- - -Updraft
LACHANDARA,
You should look through some material handbooks. Some grades of stainless steel are very ductile. I know that recommended bend radii for various grades of aluminium are all over the place.
JHG
CorBlimeyLimey,
I have had this discussion with a good sheet metal shop. They can bend "in air", but it is more expensive, and less accurate. You are better off conforming to their tooling.
JHG
To all who answered my question, thanks greatly appreciated
Check out thefabricator.com, they have an article on bending that has alot of info.
