hl3
- Feb 9, 2015
- 2
Hello everyone,
I'm new to Abaqus as well as the forum. I'm working on a project and I'm doing very well so far, being new to Abaqus and all, but I eventually got stuck.
It is a simple beam with a cross section, two loads and four support points. I split the beam into 3 parts so there are 3 sections to add BCs to. The first 2 sections are 4m in length and the last is 3m. There is a 25Nm moment force at the end of the 3m section and a uniformly distributed load of 1500 N/m in the middle section.
I've added all BCs and loads appropriately and the job completed with no errors. What I need from the model are the bending moments, but the option "SM1" is not there in the list when I go to select it. I understand that this option is only available when working with beams and I have triple checked that all the steps I've done prior to this has "beam" selected.
I don't know where to go from here. I would appreciate it if someone could guide me in the right direction.
Thank you
Thank you
