Hello all,
I am looking at a setup which includes a simply supported pipe with another pipe of same length slotted inside it.Assuming no friction exists between the two pipes, Am I correct to assume that the two pipe sections do not act as one whole section with a combined second moment of area? Instead they act as two individual pipes that share the applied load based upon their EI values?
Now what would change if the pipe ends were welded?
Many thanks in advance.
