Bending Stress in Circular weld
apetr26542
108
Welding of a circular pipe to a flat plate where the pipe is in pure bending. I've seen the weld stress calculated as
M/Sw
M=moment
Sw=circular property of the weld
Is this the Section properties of that of a circular ring, with the effective throat being the thickness of the ring?
Treat it as a section with wall thickness =1.
This gives you weld load per in (or mm)
or look in Blodgett's Design of Welded Structures. It will give you Sx in in^2 (which is what CSD is talking about by using the thickness of 1). Then when you use M/Sw, you will get K/in to compare to your weld.
Hi apetr26542
stress = M/(Zw * w)
w = leg size of weld
M= moment
Zw= section modulus of weld treated
as a line= 3.142*d^2/(4)
where d = tube dia
regards
desertfox
