Can anyone tell me how AISC calculates their properties for biaxial single angle flexure? I have a scenario where we need to use a long bent plate to carry brick. I need a 9" outstanding leg and angles only go to 8", so I need to calculate Swa, Swb, Swc, Sza, Szb and Szc.
Also, AISC referred me to their design example E.14 from their V14.1 design examples set. Their example is a single angle column with eccentric point load. In their example the eccentricities from z and w axes are intuitive since they are out of plane, but how do I adjust this for a vertical load on the plate that will be in plane with these axes?
