Best Method of machining a Brake rotor to a smaller diameter? 1
gonzowerke
Automotive
Nov 15, 2011
5
Hello All,
I am in the process of converting my 1978 Honda CB750K Motorcycle to dual front discs. I am using 1977 CB750F2 forks and calipers. I have jumped the first hurdle and determined how much I need to move the K rotors out to match the plane of the F's, but now I face a diameter dilemma.The K rotors are 295mm in dia., while the F ones are 275mm. I am trying to decide between fabricating a relocation bracket for the calipers, or trimming the rotors down. If I cut the rotors down, would a lathe be the best? or a mill? All I know about the metal of the rotors is that it is stainless steel, I do not know the grade. Thickness is 6mm.
Thanks for any info!
Chris
Chris,
If I were doing this, I would use a lathe. At 6mm thickness, you may want to have some sort of backup plate to stiffen it up a little bit, depending on how you chuck it up. Be sure to check runout in both directions, otherwise you won't be happy with the result.
Happy Turning,
Fegenbush
As Fegenbush mentioned, you will want a backup plate on either side, and preferably bolted through if there are existing holes in your disc. Otherwise it will howl like a banshee. You could also have it waterjet cut.
