Best Modeling Approach for Scaffolding Structure in Pro-E?
Laserxenon
45
Hello All,
If you have a minute, can you suggest how you would go about creating the attached file in Pro E?
It is a scaffolding based tower approximately 32 ft. tall. The model is simply for promotional purposes (ie inserting the model in a site picture to illustrate the concept), no FEA or anything like that. The joint details dont matter, neither does it matter if it is tube or solid construction, just circular x- sec. It really may not even be that important to have circular x-sec- they can be lines of a certain length as well.
I tried doing a closed sweep and this didnt work due to multiple closed sections. I thought about modeling individual elements (ie a frame) and then making an assembly of many parts, but this would be alot of work. I'm looking for a quick and dirty way to construct this to illustrate the concept, and highlight a few important dimensions.
Thanks for any input,
Drew
Modeling the components and doing it as an assembly will be the easiest. You can use mirror if both ends are identical.
Ben Loosli
There is an add-in module EFX (Expert Framework) that makes that kind of product much easier but I think it is rather $$.
