Best software to learn? 1
ST111
16
Hello. I am wondering if there is one software that is best to learn over others? Or is it really relevant? What I mean is would future employees be that bothered about not knowing a specific software, and more interested in the fact you understand finite element analysis and the underlying principles?
OS FEA : Calculix is probably the best
$50 : LISA (that's what I use at home)
Incidentally I agree with someone above, you will probably not get a job in an FEA group if you have merely mastered any of the bundled packages in a CAD suite.
Cheers
Greg Locock
This thread inspired me to write a blog post pointing you to the Free Abaqus Student Edition
This version exactly like the commercial code except for a limit in node count. It does include the manual and tutorial which has always been a major advantage of Abaqus. This way you are learning on a commercial code with fully transferable skills.
I hope this helps!
Rob
Rob Stupplebeen
Rob's Engineering Blog
Rob's LinkedIn Profile
Just saw an FE job opportunity at Apple posted on imechanica with Abaqus/ANSYS in the preferred software skill-set. So, if you are a registered student, then student or academic versions of the major codes will be an option.
Are you new to this forum? If so, please read these FAQs:
Hi again
I think that for a student to find academic licenses may not be a big problem. But going back to the original question, "Best software to learn"?
That is singular if I understand it correct and I would say it requires some specific information. Some software's are huge in one industry and more or less non-existent in another. Also, are we discussing solvers or pre-post software? I use Femap with Nastran and it would probably be easier to change the Nastran part than the Femap part.
Like I already mentioned, for a new engineer, I think that knowledge in the methods rather than in a specific GUI would be valuable. For a more experienced engineer a company would probably expect knowledge in one or more of the commonly used codes for the particular industry.
My impression is that the OP is at the beginning of a career rather than a more experienced user. So I don't thing he/she should be to hung up on the name of the software but rather on how it works. Of course, if the ambition is to work at company X or a specific industry it is a good idea to find out what software they use.
Good Luck
Thomas
