I am working on a design involving a cam and follower. The nearest approximation of the shape of the cam is an ellipse and the follower continuously rotates around the inside of this ellipse (it is an internal cam). The problem I have is that there is very little space to accommodate the follower, or to be more exact the motion envelope of the follower. I was thinking if I could line the internal surface of the Cam with ball bearings, or equivalent, then I wouold not have to use a follower with incorporated bearings thus allowing the assembly to be more compact. My question is has anyone ever seen anything like this done before. The problems I am having are, amongst others,:
a)How to maintain the ball bearings in position around the internal surface of the Cam
b)How to design a follower that will ride smoothly across the ball bearings and not create a "bumpy" effect
Any replies would be gratefully received
