Bill of Material Error
gimpala
I am having an issue with a couple of part numbers. Lines 3 and 4 have a dash and quote symbol in front of the numbered part and it is not intended. I have searched all the properties of the parts and everything looks good. The only solution I have found is to reinsert a new bill of material which corrects the problem.
 http://files.engineering.com/getfile.aspx?folder=87cd8c80-b6ba-4505-9694-2a7a9377b20c&file=BOM_Error.JPG
I have not seen that before.
Did you check "all" custom properties of each configuration?
Chris, CSWA
SolidWorks '15
SolidWorks Legion
Yeah, its a new one for me too. These are single configuration parts, I checked every area I could think would apply.
Check to make sure if you are using just Custom Properties that the COnfig specific props are completely cleared out. I have found the same property in both areas causes conflicts in all areas of the Drawing including BOM's
Scott Baugh, CSWP [pc2]
Gryphon Environmental
"If it's not broke, Don't fix it!"
faq731-376
