Bill of Material issue
Agriego
85
Good morning,
I have a drawing with parts on multiple sheets. When I insert the BOM, I click on Table>Bill of Material, then click on the detail view on the first sheet and place the view. The problem is that I have more parts on other sheets that I need to add to the BOM. How do I add these other parts to the BOM? I am using Solidworks 2015 X64, SP1.1 on Windows 7 Professional.
Thank you,
Al
When I think BOM, I usually assume that it's attached to an assembly. Is this the case with the drawing you're working with? If so, you'll want to have a view of the assembly on your front page and derive your BOM from it.
Jeff Mirisola, CSWE
My Blog
Yes, assembly on the first sheet to attach the BOM. It will populate the detailed parts used on the other sheets.
Chris, CSWA
SolidWorks 14
SolidWorks Legion
If you do not wish to show the assembly - you can still have a view off to the side that is not actually shown on the drawing. You would point to this view for the BOM.
But won't the assembly show up in the BOM in addition to the components?
Al
No, the BOM compiles all the parts in the assembly, but doesn't include the assembly itself.
Jeff Mirisola, CSWE
My Blog
Are the parts on the other sheets in the assembly? If so, they should show up in the BOM... Possibly select the BOM and play about with the 'BOM type' options in the properties box on the left?
If you have Sub-assemblies, then you should try using the In-dented BOM, however if you selected "parts only" you will only see the parts no subs. If you have any configurations that changes how a BOM will see the parts\sub-assemblies as well.
Scott Baugh, CSWP [pc2]
Gryphon Environmental
"If it's not broke, Don't fix it!"
faq731-376
