Afternoon All,
This is my first thread here but I have been reading up on and off over the years. A great source of information!
I have a fair amount of experience with wet lay up and pre-preg composites using vacuum bag/oven techniques.
However I am working on a project that would benefit from bladder moulding. It is effectively a shelled component with one open end. It could me made by simply curing the 2 halves independently using vacuum bag and then joining together post cure. But, given I have not tried bladder moulding before and would like to build my understanding/knowledge of this technique for future projects, it seems a nice place to start.
A few points to note:
- I will be using cnc'd aluminium moulds
- The part is not structural. Therefore aesthetics are priority
I have read this forum and also searched a fair bit on google so have gained a reasonable amount of knowledge to be able to give it a go. However I still have a few questions:
1) is it still best practice to utilise a vacuum bag between the pre-preg and the bladder to reduce the effect of air bubbles
2) if the above is true, how best to incorporate the vacuum valve/line and the bladder valve line into the mould
3) if no vacuum is required, does a bladder require a release film (will likely look at latex bladder)
4) I have read up a number of cases where designers have utilised a heated mandrel in the centre of the bladder. what is the reason for this?
5) lastly do anyone know of any manufacturers in the UK that can produce one off/low volume bladders
I appreciate its a few questions but any help would be much appreciated on my journey. If you know of any good guides/literature I would welcome any links.
Thanks in advance!
Thanks in advance!
