Interesting question:
ASME U Stamp Pressure Vessel - Adding a bleed ring between a blind flange cover and the vessel proper.
Does the bleed ring have to be ASME Stamped?
Is an R Stamp required?
12" Vertical Body - Sch 40/Std SA-106-B Pipe with Class 150 SA-105 weld neck flange and Class 150 SA-105 Cover (250 psi @ 200°F).
Adding a bleed ring for 3/4" vent/purge one side / 3/4" air eliminator on the other.
Studs have to be replaced to allow for the extra 1-1/2" length plus a second gasket.
Thoughts?
Thoughts?
