Blend 1
cubalibre000
1,070
which blend type or options must set to obtain the same radius in the opposite edge ?
I need to use blend feature.
No workaround.
No mirror surface, only blend command.
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
Why not just measure the radius of the blend face of interest and then create your blend(s) using that same value on the other edge?
Is the attached what you're looking for? If note, please provide more information about what it is that you're attempting to do.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
But that FACE is NOT a 'Blend'. And since it's NOT a 'Blend' why are you upset that you can't use a Blending function to create it?
Here's you desired model. I know you said that you didn't want to create it this way, but if this is what you need, then why argue over the method used to get it?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Hi John,
the real reason that I need a blend, because there is a competition between NX and other CAD.
No CAD are able without workaround to blend in the edge illustrated, but Catià yes.
I think there is a blend solution, but NX has lot of options end blend type that I don't know which to use and which options.
Thank you...
This is how (see attached model) I would approach creating a shape like this using traditional NX free-form functions.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thank you John for your approach.
Thank you...
I was thinking about how the part was originally created and I suspect it is the product of a thickened sheet. Attached is a rough recreation. My part uses a bi-direction thicken, the original probably was a uni-directional thicken.
See attached.
 http://files.engineering.com/getfile.aspx?folder=9b54a279-786e-4eed-9408-91b0d0b1e5ed&file=blend_x_t.prt
I'm also thinking that perhaps this represents a formed-part where a 'blend' was applied to a corner of the 'blank' before it was formed.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Hi mmauldin,
it's true, my attached file came from a WORKAROUND, but I'm looking for a solution with blend in NX.
Thank you...
Hi cowski,
I know that the solution with blend it's possible and your solution confirm that, but NX has lot options in every blend feature and I think that it's possible avoiding your workaround.
Thank you...
Cowski,
That's a great solution. I never really use Soft Blend. It's amazing how many functions there are that you just don't think about using.
can you tell me what blend function you used in V5?
It is maybe translation mess but the blend has nothing to do with a normal blend...
Hi uwam2ie,
I will give you the response after the competitor give me the response.
Thank you...
Hi uwam2ie,
why do you need the v5 file ?
The command image are clear.
Do you use NX or Catia or both ?
What are you looking for ?
Thank you...
By the appearance of the menu, I'm guessing that's a chordal length blend from V5.
If Shape Studio hasn't added it by now in NX, then you probably won't find a feature-based way of doing it other than what's already been posted above. Soft Blend isn't that bad of an option, but I see the user's point - why add steps to a process when it can be done without them?
I seem to recall this being one of the Edge Blend gripes I had over the years (along with Conic Edge Blends, etc.). I grew weary from fighting those battles over the years and just thinking about it makes me feel tired now. Frustrating, indeed....but I told you so! (Wink)
Tim Flater
Senior Designer
