blending silicone & other elastomer
Like...
MIL-DTL-25988 RUBBER, FLUOROSILICONE ELASTOMER, OIL-, HYDRAULIC FLUID-, AND FUEL-RESISTANT, SHEETS, STRIPS, MOLDED PARTS, AND EXTRUDED SHAPES [FVMQ]
[various AMS specs] Fluorocarbon Rubber [FKM]
See ==>SAE AIR786 Elastomer Compatibility Considerations Relative to Elastomer Selection
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
Silicone and nitrile each have their own characteristic properties, but are generally not compatible to blend with each other due to very different solubility characteristics, meaning they don't mix.
Would add to what CPro said, I don't think it's possible to make a good adhesive bond of the two rubbers either.
yes, silicon can be blended with other elastomers such as fluorocarbon, ethylene propylene, and fluorosilicon and these blends definitely improve resistance to heat, oil, and fuel, etc. Personally, I prefer silicon, HNBR, and PTFE Coated O Rings.
