Blow down Ring of a Safety Valve 1
Guest
Please explain the function and application of a blowdown ring
Do a search for Anderson Greenwood, they have lots of on-line information on safety valves, Farris would be another good site to look at.
blowdown rings accomplish two basic purposes;
1. along with the disc holder they form a "huddling " chamber that will provides the "pop" action necessary for the safety valves.
2. adjustment of the blowdown ring(s) varies the diffence between the set pressure and reseating pressure of the valve.
If you have problems with the max 3% dP on the PSV header then the blowdown ring could be your solution.
The manuf. should always confirm that its OK and of course so should good engineering judgement.
Best Regards
Morten
