I have a 1991 BMW 325i with a 2.7lt "stroker" engine (885 casting cyl head, 292 degree cam, long tube headers, 10.2:1 comp,82mm stroke, lightened stock rods, cleaned up intake and exhaust ports/chambers, balanced rotating assembly).
The engine is currently running Dbilas 45mm ITB's (individual throttle bodies) and i am building a mega squirt EMS for it.
Once the engine has had enough break in time, I would like to add a M-90 gen 5 Eaton supercharger.
the superchrger is from a 2002 (?) Buick Regal and has a built in by pass valve. I am planning on running a max of 12 lbs boost. I am also going to be running an air to water intercooler.
In re reading Corky Bell's supercharger book, I noticed that he states that roots superchargers should be used in a draw through configuration. I how ever would like to use it in a blow through application though. I can not find a reason stated anywhere to explain why he makes this statement. Can anyone give me a reason why this will not work or is less than ideal?
thank you for your help.
