CuriouslyGeorge
- Feb 9, 2005
- 27
What can you tell me about the practical meaning behind the numerical results from a blower door test??? For example, I have 1000 ft^2 area I wish to pressurize to a desired value of "x" iwg. The blower door test says I need 500 cfm to achieve "x" iwg. (I assume, a low cfm result means the room is well sealed.) But...the supply air (SA) flow to the area is normally 1500 cfm.
Does this mean, to achieve "x" iwg, I need to supply a total of 1500 cfm SA + 500 cfm more? Is that the practical meaning of the results?
Thanks,
- CuriouslyGeorge
Thanks,
- CuriouslyGeorge
