Bluebeam Revu Printing Stamps issue?
CaliEng
49
0
0
I am using an image of a signed PE stamp for document approvals. Another timestamp for this digital version. Looks fine in PDF, however when printing, the image of the actual stamp and signature does not print. Anyone had this issue? Or what is the best method for adding stamps in Revu which will print.
In your print options, make sure you select "Document and Markups" rather than "Document Only"
I also flatten the drawing and do not allow unflattening/content recovery whenever I do that. It 'bakes' the stamps into the drawing.
Happening with both, printing to printer or print to PDF. They default stamps from Bluebeam (Approved, Preliminarty, etc) work fine, its just my custom ones which I put an image into it. Any text in the stamp comes through, just not the image. I have tried flattening the stamp itself to no avail.
SOLVED: Bluebeam Stamp doesnt seem to like Images. Print image to PDF, then insert that PDF to Stamp (Can crop before insert). Prints fine now.
Thanks!
