Hello PEinc, i knew that you have delt with sheet piles design. I have i question.
In my case, i am analyzing a cantilever sheet pile.
According to the references i have read, i can do moment about the tip (sum of moments about the tip = 0), in order to find my depth value.
ok, now i get my depth, it;s a reasonable value. But my question is, when i try to check with my Sum of horizontal forces (Passive Vs active forces), they are not ZERO using that value of depth, in order to get them ZERO, i need to find OTHER value of depth.
When i get this new value, then i try to check with my sum of moments (about the tip), but in this case it is not zero,
i think it sounds a little by weird, (they should be zero both at the same value of depth), my question is, what approach should i use, the moments? or the Sum of forces?
in my case, i get a very very low value when i use the sum of forces approach ( 0.5ft Vs 12ft). With moments, makes sense.
am i going to have always an unequilibrium?
Please, reply, thanks
