jwmolddesign
Industrial
- Aug 25, 2012
- 3
I am an I-deas user trying to learn NX8.
I have imported a step file with no assembly structure into NX. The file contains about 650 solid bodies. I need to get these bodies into a structured assembly so different groups of components can be turned off and on in an organized manor. Basically what I think I need is a way to convert the bodies into NX parts. Then I can add the parts to an assembly. I don’t want to take the time to name every nut and bolt in the entire file and export as a part.
I-deas would import these bodies as parts and then I could move the parts to assemblies.
I use another software (Cimatron) where I have a switch on import which will place all the separate parts into an assembly. The parts are named Part1, Part2 and so on but then I create some sub-assemblies and move the parts to make an organize structure.
Any help would be appreciated. Thanks in advance.
