SA07
- Feb 22, 2018
- 366
Hi
Can we use the following materials for a boiler feed pump working at
Flow 30m3/hr
Head 31 bar
Temperature 120deg C
Medium Boiler feed water pH 8.5-9.5 temp 120deg C
Pump casing material EN-GJL-250
Pump impeller material Steel CrNi 1.4301
What material is usually recommended for the pump casing and pump impeller for a boiler feed pump?
Thks
Flow 30m3/hr
Head 31 bar
Thks
