I have received a couple of bolts with a rather unique markings for failure analysis. It has two lines on its head. There is no such markings in the standards. I attach a photo of one of the bolts. If you know any info on this bolt, please let me know. Thanks.
Not professing any particular expertise here, but I suspect for whatever it is worth this "bolt" (or stud?) "head" may not be a high tensile variety, as I think most common standards require those at least to be recognizably marked.
So you tighten the nut on the other side, making it more of a headed stud than a bolt really, but I realise they may still call them bolts.
Do you think that maybe the marks are there just so that you can note the orientation of the square in the part, to check that it hasn't started to round out the hole when the nut is tightened and the head may be out of view?
Bolts are not tightened by applying torque to their head-- they are tightened by torquing the nut. Screws are tightened by torquing their head. This is the consensus definition used by IFI, ASME, ASTM, ISO, etc.
You're quite correct, that is the current consensus on the definition of bolts and screws, but nearly everyone in this thread has spoken of "bolt head" including the OP. I suppose in my first post, it would have been more correct to say how do you "stop it turning", but for an old fart like me, with my formative years spent in the "infernal combustion engine" business, a "screw head" will always be something to do with woodworking and there must still be loads of old flat-head engines about with "cylinder head bolts" and millions of "big end bolts" holding con-rods together, all with hex heads, all screwed into tapped holes and then torqued down by the head!
The essential point I was making in my second post is that in the absence of spanner flats or similar and with what appears to be a plain cylindrical head with a hidden way of stopping rotation, you need something (maybe the two marks) as a reference to indicate that it hasn't turned when the nut is tightened. The nut may have seized or run up against the end of the thread if a washer is left off or the part it secures has been machined down in thickness, without a suitable witness mark, all the torque applied to the nut may just be destroying the square under the head or the hole it fits in.
I am a bit surprised at the direction this post has taken.
I had only the head portion of a broken bolt and wanted to know what type of bolt that was. I figured out from the standards that was a Grade 3 bolt (thanks to those who helped me).
SnTman,
What kind of info do you want me to get from the bolt supplier? I do not know whether it is possible.
