Mar 13, 2025 #1 J Jayaprakash K Structural Mar 13, 2025 2 Can anyone suggest the exact bolt length needed to secure this wood? The bolt diameter is highlighted in yellow. Attachments Bolt length.JPG 36.5 KB · Views: 21
Mar 13, 2025 #2 XR250 Structural Jan 30, 2013 5,882 Depends on what is on the other side of the web. You might want to bear your ledgers on the bottom flange of the beam and make them thinner (i.e. 2x and some plywood spacer) to remove the shear load from the bolts. Upvote 0 Downvote
