flyingmike
Aerospace
Morning all,
I am working on a static analysis in Ansys and have included the models of the screws so I can add pretension.
At first I added the pretension to an outer face on the screw shank. (the screw has multiple split faces on as the screw bolts 3 plates together)
Running the analysis gave me the most deflection in the bolts themselvesdue to the pretension and on investigation I could see that a hollow cylinder was stretching out from the screw. I have attached a pic to make it more clear.
I have since tried adding the pretension to the body and setting up a coord system for each bolt. The result of this was that the hollow cyclinder now stretches out of the top of the screw rather than the bottom.
Has anyone seen this before? What does it mean?
Thankyou in advance for your help
Mike
Mike
