Baffled Engineer
- Jul 27, 2018
- 57
I'm working on an old building and I observed what appears to be a sheared bolt / damaged base plate supporting the ends of a 112' span x 8' high girder truss. See image below.
If this is related to bolt shearing, is it typical to see the white substance around the bolt? I have not seen bolts fail in shear so I can't tell if the white substance is related to this.
Thanks.
Thanks.
