MALKOBANI
- Oct 16, 2006
- 21
- 0
- 0
You designed a beam carrying a UDL as fixed end connections. The shop drawings show the flanges of the beam bolted with a clip angle and welded to the column. (Typical right?). Now given that the holes are larger than the bolts, the ends will rotate if slip is not prevented. You compared the possible rotation of the ends to the rotation of a simply supported beam,( WL^3/24EI), and found that the rotation due to slip is larger. Means the beam is really a simply supported not a fixed- fixed one. What would you do?
